AiM Data Sessions are AMAZING!
The seminars sound great - did anyone video or something? Bit hard to make it as my car only has one wing although there maybe web fora coming up. Keen to pick up some of the tricks now that I finally got the dashware/solo data synch right ... But it's not easy vs the smarty cam that's for sure.
That being said, I have access to a "virtual classroom" setup that I could use to stream and record one of his sessions.
All he would have to do it to deliver his presentation while sharing his ppt using a web tool. Voice can be captured simply by using a regular speaker phone... If he has a webcam, I can get that too...
(see http://www.webex.com for more info).
If anyone knows him well enough to ask, I could probably set this up so everyone on rennlist can watch his session...
Regards,
T.
Basic Site Sponsor
Basic Site Sponsor
Received 3,315 Likes
Information is power!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Sensors vs Long G again
Peter
Thanks for your comments. I decided to look at Long G from Motec using an accelerometer. I can totally see what you are talking about now. The GPS Long G does not come close to a real accelerometer. I still prefer sensors, but this does give me something that I was not using. Thanks
Below is a similar graph, but different car from the prior chart I posted
Basic Site Sponsor
Basic Site Sponsor
You can see why I like it as an accurate measure of even what the driver input on the pedal is, in lieu of and in addition to the pressure sensor, if the car is so equipped.
Rennlist Hoonigan
which cost no drachmas
Jerry, THANKS for posting that! Look at the great correlation, (almost a mirror image!?!?!) between brake pressure and Long G (accelerometer derived)! Look at THAT, Matt!
I am going to be using...
the RLC Racing unit this weekend. Have a brake pressure sensor and will use it for the first time this weekend. Have brake pressure sensor installed, will use the accelerometer for acceleration. I will install a string potentiometer for the throttle one of these days.
I have a lot to learn...just firing up the unit for the first time at the track. Really excited about taking this leap, long overdue.
I have oil temp and pressure lights wired in as well, mid-range warnings and full dash light up in Red in case of a dangerous oil temp or pressure condition.
RLCRacing.com is right in my home town, Paso Robles, CA. They make their products right here in the good ole USA.
Off topic, just bought some running shoes, New Balance. The shoe is labeled "Hand Made in the USA" I like this!!!! This balances out the equation for the Red Wing work boots I bought the other day, Made in China. The USA boots didn't fit as well...both priced about the same, so I have addressed the trade in-balance problem, in my own little way.
Basic Site Sponsor
Basic Site Sponsor
I was pointing out to you (Look at THAT, Matt!) that our premise has been substantiated with Jerry's screen capture of nearly identical tracings (and timing of the attack and release of those forces) in the overlap of BP and LongG (accelerometer derived) graphs. It's GREAT!
What this means is your use of LongG (acc) in the Solo is a usable and highly accurate assessment not only of stopping force, but the way that stopping force is achieved, directly from the movement, timing and force of the brake pedal actuation.
This reaffirms what we both said, which is that LongG is suitable for objective assessment without the need for the BPS. The BPS is nice, but not mandatory.
Basic Site Sponsor
Basic Site Sponsor
Rennlist Hoonigan
You and I were trying to make the case for using LongG as an effective, accurate substitute for brake pressure sensors a while ago on another thread.
My first day back on track this year is in a week and a half. I'm very excited to get into some new data again. I have big plans for improving my driving this year.
It is important to clarify that the built in accelerometer is far more accurate than the GPS derived Long G. So, for people using SOLO or DL, you need to calibrate the internal accelerometer and pick that when looking at the data. I've also noticed that The Long G is really mis-marked (at least in the early units, not sure if it has been fixed), so verify that too.
I set up an EVO4 and Micron 3 unit yesterday and changed my plan to install a brake pressure sensor, based on Peter's comment (I'm still using throttle sensor though). The EVO4 unit has a built in tri-axis accelerometer. If this works, as I expect it will, this is a big savings on work plus about 200 bucks in parts. Another step forward due to Rennlist forum!
Update: It appears that AIM does have the internal accelerometer labled correctly, so no worries there. You CAN calibrate the accelerometer for the SOLO in Race Studio 2. Click on device configuration and select SOLO DL. This does work for the SOLO, I just did it. For some reason, the accelerometers are at about 4 G when shipped from Italy, so you need to do the calibration.
Basic Site Sponsor
Basic Site Sponsor
Great news, Jerry. Agree with you on the throttle trace value. Of course, most all OBDII and CAN equipped cars have a TPS value, but few have brake pressure.
I've been auto calibrating the Solo units (both Solo and Solo DL) since the beginning because, until a friend of mine showed me the GPS derived accelerometers, I completely missed that it had them!
This is a great exchange of information!
Basic Site Sponsor
Basic Site Sponsor
It is important to clarify that the built in accelerometer is far more accurate than the GPS derived Long G. So, for people using SOLO or DL, you need to calibrate the internal accelerometer and pick that when looking at the data. Another step forward due to Rennlist forum!
The fact that the VVBOX uses only GPS derived accelerometer data has made it more difficult to use that as a measure for driver development, as the AiM GPS LongG has the same issues.
All is well with the accelerometers, though.
