Trailer ramps
For what it is worth, I did not use the rivets. Holes were drilled and metal screws hold everything in place. I simply don't trust rivets, especially when it comes to loading and unloading. GL with your search.
It was sarcasm. i've watched a few guys load this way and the tears that flow when the board snaps half way up the ramp and the splitter or nose gets damaged. save a few hundred, spend a lot more....
It’s quite sturdy and was likely cheap. The big downside is they’re enough wood to be heavy and a bit unwieldy. Makes sense for a small budget, but I’ll pick up some race ramps at some point.
I couldn’t understand someone driving up an board into a trailer. It’s just not stiff enough.
Tip: pop off the splitter before loading the car. The cup car splitter on my GT3 takes 10 seconds to pop off or clip on. Really reduces the need for using ramps. I have looonnnngggg two piece race ramps, if I remove the splitter I only need the last half of the ramps. I stack them on end (vertically) and strap to e track in the rear corner of the trailer. Safe, secure and handy for loading/unloading
Thats because they didn't put a brace under the board to help stabilize, add support, prevent the board from flexing too much. But then again I've seen alu ramps that had an S shape because the guy who bought them thought the 1000 lbs rating applied to each ramp individually and NOT combined as a set.
Thanks MB, but if you read my initial post I was asking for feedback about pitpal ramps and people who have direct experience. I don't have any interest in building wood ramps, nor do i have a vendetta against them. Everybody has their way, that is one that I don't have interest in. SWK6, thank you also for your feedback, just what I was looking for.
This company has a calculator tool for determining required ramp length.
https://reverselogic.us/race-ramps/
M_Weining (08-06-2020)
The owner of ReverseLogic was very helpful when I was shopping. Through his help I was able to find a one piece progressive incline ramp that met my needs and kept overall length manageable.
The increasing incline is a great help.
