Windshield mount for iPhone
not sure what you guys are referring too. I can video in parallel with all the data capture(run it so that start stop on the video is the same for start stop on the session). i can then either pull the video out separately without the data overlay, or layer the data on it into a separate video file. Video editing can then capture whatever portion of the video you want to save.
Rennlist Hoonigan
which cost no drachmas
I have the large Ram suction cup and it is very strong. My concern is whether PCA will allow suction mounted cameras in their DE. Any advice? Dave
http://www.rammount.com/CatalogResul...5/Default.aspx
They do sell mirror mounts that replace the stock mount and hold both the mirror and the phone, but only for the usual suspects (Ford, GM, Chrysler) I couldn't see anything for Porsche.
Here's a crappy picture of mine:
Rennlist Hoonigan
This kit will get you everything you need, its technically to mount a phone to a bar on a bike, but it uses a unversal u-bolt approach that works well on rear view mirrors as well:
![](https://lh6.googleusercontent.com/-8xSrEPyejUQ/UA__tYsRb1I/AAAAAAAAAIM/5c-Gj2NnYrk/s800/005.JPG)
mophie.com has some mounting attachments for the iphone (including a wide angle "over" lens). But, this may be for a different application (camera) than what you have in mind.
I attached a 5 case to my old 4s windshield mount. To be honest it works better than the tom tom mount, especially on bumpy sebring. I also use a dual external gps antenna that connects via bluetooth and gives me much more accurate car placement.
http://www.youtube.com/watch?v=dKJz8...ature=youtu.be
