FS-86 944 chumpcar - THE DRAGON
Sad to say the Dragon needs a new home. Time to move on to spec racing and i cant maintain two race cars. The dragon needs a home so if you are looking for a proven chumpcar or you want a car to do DE's that is fully caged or something to clean up into a nice spec car or track car- this is the one.
1986 944 chassis - odo stopped at 201k awhile ago - i do have a clean title in my name
-motor was recently rebuilt w/ 84 donor
-crank polished-
-new rod/main bearings
-all New gaskets
-late oil pan w/ lindsey baffle and factory crank scraper in pan.
-Has about 49 hours on it now- used less than 1 quart of oil in this weekends 25 hour race. Does have small leak but could not locate.
-kevlar timing belt and brand new rollers
-very nice water pump installed at build but not brand new
-new air filter and just installed
-good alternator installed at last race
-has a/c pump on it but no hoses
-ok cap,rotor- has new lindsey firebraid wires
-idle valve and all emissions removed
-cat removed and muffler replaced w/ cherry bomb and tail pipe- sounds good not too incredibly loud
-NEEDS ALTERNATOR BELT IMMEDIATLY
power steering works and doesnt currently leak- hasnt used any fluid in a long time- i do believe the clip that holds the shaft inside the ps pump may have come off, easy to put back together
-factory suspension- added factory rear sway, 26.5mm front sway
-250lb weltmeister front springs
-new monroe strut inserts
-ball joint and inner/outer tie rods all feel tight and front wheel bearings are new
- rear bearings replaced about a year and a half ago
-trans is factory w/ swepco fluid replaced before the last race- nice short shift kit installed (not schnell)
-axels stock- regreased this year not clicking
interior
-custom rollcage by Mongoose chassis- chumpcar/nasa/pca legal for racing
-new 6pt harness on ds installed this year
-OMP driver's seat, non-reclinable w/ slider- fits our drivers 5'7" to 6'5" so far
-brand new drivers window net installed- nasa/chumpcar and pca legal
-i also have a reclinable passenger omp seat on sliders w/ an expired 5pt belt that can go w/ the car
-momo steering wheel w/ detachable hub
-skull shift ****-gotta have that
-custom center panel w/ switches for headlights high/low beam - fog lights - wiper high/low and aux. switch.
-power cut off switch in center panel- kills motor and battery- legal for chumpcar and maybe pca/nasa-only variation is location.
-all extra wiring deleted, no heat/a/c or blowers
-dash cut across center for knee bar, factory gauges all work
-ebrake still works
-wheels- comes w/
8x early offset 15x7 phone dials w/ used but somewhat good street tires
- 4x ES100 225/50 yokos - one chorded slightly
- the others are 2x Dunlop Direzza star spec 205/50's and
-two are Falken rt512's 225/50 in decent shape.
All are legal for chumpcar or good for street. All wheels are straight and painted key lime green to match lower half of car.
brakes
-factory brake calipers
-braided stainless brake lines this year
-uses super blue race fluid but needs flushed now
-hawk hp+ rear pads - lots of life left
-hawk blue front pads- have about 2/3rds life left
-NEEDS front rotors - bearings replaced before last race
-master cylinder replaced two years ago
-rear rotors ok
body- body is not so great but usable -
- ps quarter is straightest, pretty good
-ds quarter has been pushed in and popped back out and has a dent behind ds door.
-DS door is ok.
-PS door has crease along lower
-DS fender is pretty beat up as well as PS fender which have both been wrecked and fixed about three times.
-windshield replaced w/ crack free one
-sunroof stripped and glued in w/ two metal brakets to secure towards rear
-stock rear hatch
-stock side rear windows
-stock door windows- all regulators removed, windows drop in and have pins to hold them up for transport- doors NOT gutted completely
-hood ok- has early 924 hood rod to hold up
-taillights replaced w/ metal and has trailer lights installed-lenses broken at last race but replacements are cheap at -anywhere
-headlights are stock but motor removed- manual wind up-ps lid currently removed as it came loose during last race
-large removable fog lights mounted to braket that bolts to nose panel- uses factory headlights
-front and rear bumpers have coil springs mounted over shocks so they pop back out in case of small incident- works great- easily removable
-lower valance- chewed up but amazingly nice shape for a race car
-FACTORY GAS TANK 21 gallons - great for endurance racing- stock pump-new filter
The car is an actual race car and does very well at it, and it shows. It is however very stock. Runs great, very much fun and handles amazingly well on track. LIke i said this can be good as is or great w/ some more work. Looking for $2500 obo - can include some spare parts not for sale separately. PM me or call 5132-400-6883
-crank polished-
-all New gaskets
interior
-ebrake still works
-wheels- comes w/
brakes
-rear rotors ok
-DS door is ok.
-stock rear hatch
Thats a great deal for a dialed in Chumpcar. Dan's build's are amazingly well turned out, from what I've seen. GLWS, and I'm thrilled that your moving back to the Spec racing fold. Neal & Sam have been wanting to kick yor *** for some time, instead of just co-driving with you!
Administrator - "Tyson"
I cannot believe I didn't meet you guys at Road America this year.
My friends were "racing" the green 40hp Datsun from Kansas.
i think the Datsun was right near us in the pits- i talked to the team about the car because it looked awesome.
SOLD- The Dragon is going to TX to add to Flat out Racing's fleet as they have a 924s currently.
The father / son owner of the car were my first race team back in the 1986 or so. We were part of the testing crew for Heartland Park Topeka before it opened.
They are great people, will give you the shirt off their back and even parts off their car if necessary.
Quit Smokin'
This has got to be Clancy and his son... I pretty much had it guessed from 40 horse datsun from kansas... There can't be too many of those!
Looking forward to it's arrival.
We had some engine down time this year in the 924S and I don't want to miss
any races next year -- so bring on the Dragon.
When they're both up and running -- we'll consider dual entries.
Wonder what the rules are in Chumps -- I've seen folks swap engines in the midst of the
race -- how much has to be original on the car of entry during the race :-)
Maybe we'll be the first Chumps relay team!
Mike
Mike
