E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old 03-05-2015, 06:53 PM
  #5806
sbelles
I'm in....
sbelles's Avatar
I think everybody let off a little at the end. I did because I wasn't going to catch Justin and I had a good margin over Sysgen but the gaps stayed pretty constant even after I did.
Old 03-05-2015, 11:30 PM
  #5807
Burkey
Burkey's Avatar
Originally Posted by OmniGLH
Thanks guys
I think I just got lucky - all the tracks so far this season have been tracks I really like. If I have to run a track I'm not fond of I fall off pretty quickly and just try to survive. Tracks I like, I'm confident and can push harder.
Last night I pretty much kept my head down and pushed as hard as I could until a few laps after Justin fell off. I ran about as hard as I could the first few laps (especially after I murdered Justin and Burkey @ the start LOL) maintaining (and even besting) my qualifying pace and noticed that I wasn't really gaining anything - so those two guys must've been pushing hard too as the gap stayed pretty much the same in the ~2.6-2.8 range. Far enough away to not catch my draft but close enough that even a little bobble would cost me a position. I knew if they got in front of me it would be tough to get those spots back.
When I noticed Justin was gone, the gap back to Burkey was a little bigger. I pushed a few more laps and noticed the performance seemed to be falling off so I relaxed a little, comfortable giving up a few tenths here and there since I had a margin to play with. The gap stayed the same though so Burkey must've done the same thing...
I have no idea what happened at the start, I always just peg it to the rev limiter and pop it into first, usually bogs and then hooks up pretty good, last night I lit up the back tires and was headed straight for Justin, would not have been easy to explain Jim I was having the same issues at the end of the race, tires were going a little and I was pushing too hard kept making little mistakes, all good though was a fun race.
Old 03-06-2015, 11:27 AM
  #5808
User 52121
User 52121's Avatar
If I bang it off the limiter and drop it into 1st (with TC set to 1) it will light 'em up big time for me, every time. It'll bog if you have TC at 2 or higher, and it'll bog if you dump the clutch (vs. just slamming it into gear).
I was having fun at the 24 doing it as I left the pits, painting fresh stripes out of the stall after every stop. Probably because deep down I'm just a big dork and love seeing the real GT3 Cups do that when they pull out of the pits.
Old 03-06-2015, 02:47 PM
  #5809
masterianvii
masterianvii's Avatar
Sorry I missed the race on Wed.
There is also a third method for taking off smoothly, and that is to simply put it into gear without touching the pedals. Auto brake and auto clutch will be engaged. As soon as the lights go green, you mash the throttle. The auto clutch will release relatively slowly, and you'll get pretty much perfect traction without any actual TC.
Old 03-06-2015, 03:08 PM
  #5810
Sysgen
Sysgen's Avatar
!! Never tried that ! Thanks for the pointer
Old 03-06-2015, 05:32 PM
  #5811
masterianvii
Yeah, it's really silly that you can do this, but I guess iRacing sees the need to have auto-cluch at 0 speed. Might as well exploit it.
Old 03-06-2015, 09:32 PM
  #5812
User 52121
User 52121's Avatar
I will have to try this...
Old 03-07-2015, 10:01 AM
  #5813
User 52121
User 52121's Avatar
Ok if it works it must only work at the start of a race? Definitely doesn't work from a stop in the pits.
Old 03-07-2015, 02:11 PM
  #5814
masterianvii
Are you sure you're not pressing any pedals and have shifted into 1st gear?
It works for me just fine from the pits. Here is what happens:
1. Press nothing!
2. Shift into gear, still pressing nothing else
3. Mash throttle.
You'll see that the brake gets gently and automatically released, while the clutch holds a position for about 1 second. No wheel spin.
The data is from the RUF Track. No auto-clutch, and no aids of any kind.
Old 03-08-2015, 08:19 PM
  #5815
User 52121
User 52121's Avatar
Road America:
Old 03-10-2015, 04:28 PM
  #5816
JustinL
JustinL's Avatar
I've been seeing something about a change in the way springs and suspension are modeled, so we may all be scrambling trying to figure out our setups right before the race tomorrow.
  #5817
User 52121
User 52121's Avatar
Crap is there a release tomorrow?
Old 03-10-2015, 11:47 PM
  #5818
Burkey
Burkey's Avatar
I am out tomorrow, was supposed to be home but had to fly to Dallas
Old 03-11-2015, 11:54 AM
  #5819
JustinL
JustinL's Avatar
Should we run another season starting next week? The weather is starting to get better, so I'm worried that participation might slow down again.
Old 03-11-2015, 12:12 PM
  #5820
masterianvii
Which track are you guys running tonight? Monza?
The changes are modeled flex in suspension joints, which will require higher ride heights and stiffer springs according to Eric Hudec.
Quick Reply: Rennlist iRacing thread
