Twins Turbo Motorsports Supra Vid.
Old 07-12-2011, 04:31 PM
  #46
TRT41
TRT41's Avatar
Originally Posted by Astroman
Tell us your name.
We're all amongst friends here.
it's Frank Bullit, again.
Old 07-12-2011, 05:13 PM
  #47
Veloce Raptor
Veloce Raptor's Avatar
Received 1,539 Likes on 812 Posts
Originally Posted by KluberNeocon
As for 'matching revs' on the downshifts - waste of time. You can get deep into your breaking zone , pull ONE downshift and reingauge the clutch again - all FAR quicker than you can brake/heel toe , downshift , heel toe , downshift again and THEN reingauge the clutch.
The speed in which you can get from Braking Zone (begin applying brakes) to Turn In (back on gas) is far quicker doing it the way this Supra driver does it - vs. the match-rev method. Not even close.
Modern gearbox's don't care one way or the other. Gearboxes from the 'old days'... yeah they cared.
BWHAHAHAHAHAHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!
Are you serious?
Old 07-12-2011, 05:41 PM
  #48
sidney004
sidney004's Avatar
I really miss Mark.... He would of added some spice.
Old 07-12-2011, 09:22 PM
  #49
mglobe
The Penguin King
mglobe's Avatar
Are you serious?
Remarkably, yes he is.
Old 07-12-2011, 09:52 PM
  #50
95m3racer
95m3racer's Avatar
I'm glad my little comment morphed into a 4 page thread - some good info posted, unfortunately for the OP, its been 99% for Heel toe...not surprisingly.
Your theory just doesn't add up, and I think its easy to conclude the driver in that video (as it seems its not you?) would benefit from learning how to heel toe.
Once you push the clutch in, your rpm's drop, by the time you shift and release the clutch, even if you are very fast, your rpm's are going to be too low to match the lower gears RPM. Just no way around it, heel toe FTW!
Old 07-12-2011, 11:12 PM
  #51
genikz
genikz's Avatar
I don't want to get into the argument, but here is a 924S (944) heel-and-toe video of mine. I find the pedal arrangement very condusive to heel-and-toe.
My VW GTi, now that car was impossible to heel-and-toe.
And be gentle, I know its auto-x, but its $30 and allows me to use my car more often than strictly track days.
Cheers,
Chris
Old 07-12-2011, 11:17 PM
  #52
Veloce Raptor
Old 07-13-2011, 12:50 AM
  #53
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
Originally Posted by sweanders
It's the Stig.
Old 07-13-2011, 10:24 AM
  #54
GT3 Techno
GT3 Techno's Avatar
As I slow and approach the trun-in I QUICKLY rip the downshift and almost simultaneously reingauge the clutch (left pedal out). There is NO period of coasting with the clutch depressed.
If you do this "as you slow" while pushing the throttle to match revs, meaning you are still braking, this is called heel & toe... skipping gears to downshift to the lowest is a question of preference only.
You take your right foot off the brake pedal (all your slowing is done by now) and feed in gas pedal as you release the clutch pedal to smooth the transition and keep from shocking/dragging the rear tires.
This is different obviously but this is certainly a slower process as you HAVE TO coast if you feed the gas pedal with the clutch depressed while you are not braking. You could brake later if you would do this while still under braking.
Old 07-20-2011, 05:20 AM
  #55
helennsandra
6th Gear
helennsandra's Avatar
Wow, any more videos of the car. It looks great to me, what a crazy speed. It’s a killer for me.
Quick Reply: Twins Turbo Motorsports Supra Vid.
