Tbolt NJMP Driving the line...........
T4 more curbing and stay track left as you head to T5. You want hard throttle just after the apex then hard brakes (straighten the car) before trailing to the inside of T5 (not the outside wide line). If you look at the curbing you will see the paint is worn out completely on the fast inside line. That's a bunch to handle with your current monster and some nice driving to stay on top of it.
I really thought this track would reward HP but it really doesn't. It's extremely technical and you really have to manage power delivery. I ran my fastest lap in NASA TTU trim (510HP) in the one cool morning session we got when I was bedding in brake pads
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Phil send your das file and I will overlay it apex speed in t4 should be at least 90mph (95would be really good) t5 does continue on to a short straight but look at length of t4 and you will see the pay off
I"m not sure I have a das file. What is that exactly? I simply use GoPro (records in MP4 I believe) and no telemetry.
Phil drop me a direct line at bob@tracksidedata.com. I will get you a video and info on the trade off. You should pick up .5secs in that turn even tossing T5. Always fun to watch you drive that car at the NASA events.
+1. Based on my limited experience (but supported with data) T4 has to be maximized, even if it means taking 5 from only 1 to 2 car widths from the left at entry.
+2 abso frikking lutely. Done right, 5 is no slower taking this tight approach, providing your entry attitude is not pointed away from the corner. And the advantages of maximizing 4 are manifest...
T5 is slower by about 5mph apex speed (inside line) it is however shorter in distance and the time relation is almost the same then. The x-factor is your top speed before T6 is not affected much if any different. The trajectory taking the inside line gives your better release at exit so you catch up on speed. The grip of the surface has been conditioned for the inside line with lots of rubber. Lat G traces show this. I have a good "before and after" with a fast H car I worked with. He def picked up time there.
We're saying the same thing. My data shows the segment of turn in to track out for 5 is statistically identical either way (even with slightly lower apex speed), and as you point out, there are distinct disadvantages of coming in wide, driving all that disttance, and missing the inside grip.
While I am a big fan of data, and have been using it for about 5 years now. I believe a quick track walk, for those without data, will help explain what Bob and Dave are saying. Turn 4 looks very different from low and trackside, than it does from the stands. The large camber changes in turn 5 cannot be seen as well from the stands either. Spending 15 minutes on the track in that area on foot will help makes this easier to grasp.
If you stand at turn in for 4 you can actually see a small straight through the very large radius corner. Standing at the apex of 5 you can see the elevation changes to midtrack, and then it kinda stops and flattens.
This has been a wonderful thread, I hope to we can all contribute and expand it
Let's expand it then. Why are most people not driving a rimshot line to get to the entrance of the octopus? Doesn't it make it harder to turn in the car if you come into it at too flat an angle?
