To minimize understeer - tire or bar first
Old 06-20-2011, 02:39 PM
Greg H.
Greg H.'s Avatar
Default To minimize understeer - tire or bar first
Is it possible to have too big a rear tire on a car? I have a 993TT and am using 315 R comp rears (the car came with 285). Is it possible the car would be faster around a track with narrower rear tires? I have a little more adjustment in the bars - I can go 1 holes softer in front and one hole stiffer in the rear. Which should I try first - bars or tires? I need new tires, is the reason for my question.
Greg H.
Old 06-20-2011, 02:41 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,616 Likes on 838 Posts
tires
Old 06-20-2011, 02:42 PM
coryf
coryf's Avatar
What size front tire/wheel? What type of alginment are you running? Track only or dual purpose?
Old 06-20-2011, 02:46 PM
M758
M758's Avatar
Sway bars are for fine tuning. You can use them to fix a handling issue, but that is a band-aid until you can fix it right.
It is possible to have too much tire for a car. However I am not about to say that is your problem because I don't know enough about you car.
Old 06-20-2011, 02:58 PM
Doc GTO
Doc GTO's Avatar
Ditto, more info needed!
Old 06-20-2011, 03:01 PM
Greg H.
Greg H.'s Avatar
I understand there are a lot of variables the most important probably being me. I was just trying to keep things simple. It's a dual purpose car, but the street driving mostly consists of driving to the track on the highway. I'm using Nitto NT01 245/315. Have Pss9 and TRG bars (which are relatively thick compared to what Porsche offers) I have a thread going on the 993 forum discussing alignment, but let me just say I am trying to align it to maximixe track performance. Camber at -2.3 in front which seems to work and -2.4 in the rear which I might lower based on wear and tire temps. -.15 total toe in front and +.5 total toe in rear (which seems a bit much to me).
Greg H.
Old 06-20-2011, 04:33 PM
e9stibi
e9stibi's Avatar
What rim sizes are you running?
Old 06-20-2011, 04:41 PM
JustinL
JustinL's Avatar
Tire temps?
Old 06-20-2011, 04:57 PM
Greg H.
Greg H.'s Avatar
18" rims, 8 and 11
Not sure the temps are going to help. As was pointed out to me, the track i got the temps are is terrible for taking them because the tires aren't being stressed anywhere near the exit. The only thing of interest is that I'm getting the fronts up to 190 and the rears only up to 170 -175.
Greg H.
Old 06-20-2011, 05:09 PM
claykos
claykos's Avatar
Originally Posted by Greg H.
18" rims, 8 and 11
Greg H.
Where does it understeer? Corner entry, exit, middle, everywhere?
That tire temp distribution definitely points to understeer. Start with less rear toe in, go to 0 toe on the front or even a touch of toe out, and a bit more camber in front. See if that helps. Might need to do a spring change.
edit: I was misreading your toe settings, I think you already to have some toe out in front. So just go to a bit less toe in on the rear.
Old 06-20-2011, 05:12 PM
Greg H.
Greg H.'s Avatar
My complaint is mid to exit. Probably everywhere, although I am trying to trail brake more and more.
Greg H.
Old 06-20-2011, 05:24 PM
himself
himself's Avatar
Greg H.
FWIW, I run the same tire sizes on my 996 GT3 and I think 315 is not enough rear tire. I don't see understeer anywhere with this setup, but get oversteer pretty much every where, with rear on full soft and front on full stiff.
I would be concerned that you are using too much steering angle, which is causing the understeer and the higher temps. You might consider having someone ride along, or grabbing a ride in a car with someone who is versed in the NT-01. It's a different animal than a Hoosier R6 for sure.
-td
Old 06-20-2011, 05:38 PM
Cory M
Cory M's Avatar
more set-up info needed, but:
adjusting swaybars is free and takes about 5 minutes
993TT is all wheel drive, probably a big reason for the understeer
Old 06-20-2011, 05:50 PM
ubercooper
ubercooper's Avatar
If your getting understeer than you need wider front tires... those 245s clearly not griping enough. Even newer GT3 come with 275 fronts and 335 rears
Old 06-20-2011, 05:58 PM
JustinL
JustinL's Avatar
Personally I would adjust setup before buying new parts, otherwise you may be chasing the same issue with a new set of tires.
First thing I would do is get a good tire temp reading with Outside, Middle, Inside for all 4 corners.
Do you have adjustable shocks?
Quick Reply: To minimize understeer - tire or bar first
