Das Sport roll bar,are harness guides necessary ?
Hey guys,
I recently picked up a used Das Sport roll bar for my 89 911 Coupe and the PO cut off the harness guides ...
Are they necessary or is there an alternate method to keep the harnesses from moving ?
That was the whole idea behind getting a roll bar as i plan to get some Recaro's over the Winter and installing harnesses for next year's track events !
Should i weld some guides in before i repaint the roll bar ? I do approx 12 track days per season
and the rest of the time it's street driven !
Any feedback would be appreciated as i'm going to repaint the roll bar tomorrow ...
Cheers!
Phil
Cheers!
Phil
Hey guys,
Cheers!
Phil
Cheers!
Phil
every installation is different but here's a trial w/ both in place
![](https://forums.pelicanparts.com/uploads18/4_13_10_1308443391.jpg)
the outer might have been ok but the inner was way off where it needed to be.
you need to sit in the seat to see the fetch of the harness
![](https://forums.pelicanparts.com/uploads18/4_14_10_+0041308443633.jpg)
then adjust the collars accordingly, put some tape over mine in order to keep abrasion to a minimum, there should be s slight narrowing dependant on the distance from shoulder to bar
![](https://forums.pelicanparts.com/uploads18/4_14_10_+0021308443768.jpg)
Thank you Bill !
I think i prefer the collar route as compared to welding back the guides which will most likely be
in the wrong position anyways ...
Regards !
Phil
Regards !
Phil
I'm simply pointing out the facts. He said he's "going to get" Recaros, which means to me he has stock seats. PCA changed regs a few years ago that you cant run harnesses without guides. Stock seats/no guides=no harnesses.
Guys,
The Recaros and harnesses are for next year only ... the bar is going in tomorrow but i'll finish the season with my stock sport seats and seatbelts !
The PO supplied the guides that he cut off but rather than weld them back on in the wrong position it looks like i will be going with the collars instead which can be positioned correctly ...
Cheers!
Phil
Cheers!
Phil
The guides are more likely to do more harm than good if you have a DAS bar and racing seats. Without the guides, the belts will self center behind the belt holes in the seats when tightened, and will be optimally placed. If the guides are a little off, they will only chaff the belts. That is what happened in my case, anyway. I removed the guides, and the system worked a lot better. Guides would be helpful if you are using stock seats, because they will not be directed correctly by the seat cut outs.
Mr. Excitement
The roll cages can have guides. The seats have harness holes.
Guys,
Cheers!
Phil
Cheers!
Phil
I was wondering about those collars as well as they seem rather expensive on certain "performance" sites ...
Anybody have any suggestions ?
Just to clear a point... stock seats ans seatbelts for this season,all the other stuff will be a Winter upgrade !
Thank you for all your help guys![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Cheers!
Phil
Cheers!
Phil
