Das Sport roll bar,are harness guides necessary ?
Looks like something like this would work. Anybody know the diameter of the DAS Sport bar for a 993?
http://www.mcmaster.com/#split-shaft-collars/=cud0eq
Like Astroman, I just connect mine together with zip ties so they don't shift around.
The holes in the seats are a requirement for harnesses. I'm not sure if the guides will suffice with stock seats.
I've GT Recaros with holes, and I wrap my belts in the bar as noted above.
Phil, buy the Shaft Collars at McMaster-Carr. They are only about $13/ea.
I assume you will be wearing a HANS. Go to the Schroth website and look for the Harness Install Guide. There is a correct way to install and everything else is a mistake. The angle at which the belts enter the Harness Holes is the critical part for proper (tested) HANS function on impact. Get the 6 point belts if you haven't already bought 5 pt. That will make both you and your wife happen.
You can also use hose clamps over rubber gasket material, one on each side of the wrapped belt. But I have a DAS bar and they aren't needed so long as the run to the seat holes is straight and not too long.
Randy,
Thank you for the info,i will get the collars from McMaster-Carr as i don't think they are cheaper anywhere else.
Got the roll bar installed last night,i think the hardest part was reinstalling the front seat ... lol
Thank you to everybody else who chimed in as well
Cheers!
Phil
Cheers!
Phil
Thanks, Bill. Makes sense.
I have my DAS bar, GT3 seats, HANS and 6pt harnesses newly installed, but have not propoerly and thoughtfully optimized fitment, angles, etc.
That's next on the list.
Best,
Matt
Best,
Matt
Hey Matt,
Would that be after tomorrow morning's bacon and eggs ???
See you at the track ,weather looks good for tomorrow
Cheers !
Phil
PS: Derek and i are planning our seating improvements as well ... lol
Cheers !
Phil
