Rookie - Tire Strategy?
#31
Advice specific to R6s (all i know) and based on my personal experience/observations in PCA CR....
Use your best used tires for sessions which don't count for your grid position of race 1. As for new tires, you will maximize your chances of success with them in qualifying if you used them once before and were able to adjust pressures at the end of the session (it's amazing how many folks go out on stickers in qualifying or to race only to discover that pressures were way sub-optimal...). If you don't have the chance to do one pre-session, then go out on stickers for qualifying... try to come in after a few laps to check pressures and go back out (that's something you won't have the luxury of doing in a sprint however... you could do it in an Enduro...).
My 2 cents. Good luck.
#32
This is not as easy as it appears... I have never had all 4 tires rise by exactly the same amount. Each tire will rise by slight different levels depending on which corner of the car based on the track. Ideal starting pressures for Miller motorsports park for exmaple varried by 1-2 psi per tire all to equal the same hot pressure.
#33
Joe, I haven't run NT01's on the race car (968 E class) only Hoosiers, came with Hoosiers. Only NT01 experance is on the 911 DE car, still have a new set for that car of course not the right sizes for the 968. Aug. last year is when I bought the 968 car, and was already a well prepared E class car, so been learning the car late last year and begining of this year. So its all set up for Hoosiers and the data I received from the PO support that config.
#34
If someone is buying new hoosiers, I'd hope they know how to set their cold pressures so the tire comes up to the correct pressure and temp. This applies to a qual session and during a race, they will be different. Qual should only be 2-4 laps, if you can't get a fast lap in that time, you're never going to get it.
And i bow to you for getting pressures right from the get go. I'd love to know how to do that...
#35
#36
As I said, my advice is based on my very limited experience as a continuously learning D and E class PCA racer... And you're either a pro or temporarily full of hot air with your 2-4 laps remark. It's not true at all unless you are assuming a clear track. Don't throw stuff like this out to a guy who is asking advice as a rookie dude, no matter how great or experienced you are.
I'm not pro, just a decent club racer. Getting space, then ripping off a flyer or two should be common practice. If a driver is that inconsistent so that cant be accomplished, then sticker tires are not something to be worried about. Dude.
#37
There are multiple people reading this, and no need to treat a rookie with kid gloves. He should see what the front runners are doing, stuff i'm talking about, and start to incorporate these things into his own routine.
I'm not pro, just a decent club racer. Getting space, then ripping off a flyer or two should be common practice. If a driver is that inconsistent, then sticker tires are not something to be worried about. Dude.
#38
I've raced with SG-M3 and yes, he is pretty quick on track
#39
+1.
#40
If on a budget and can't afford new set of tires each race weekend, I'd have a set of wheels with Hoosiers for Quali ONLY. If you're not in the front of the pack, then use a Nitto NT-01 or Toyos for the race. If you are close to the front of the pack then you almost have to use the Hoosiers for sprint race to stay up front.
If the goal is to set the fastest lap possible then the Hoosier set should last you several race weekends for qualifying only. Lap times during a race usually are slower than qualifying thus the use of lesser tires.
All older tires used for practice.
For an enduro, go with an NT-01.
Once again this is for a person on a budget
#41
Very fast guys will set-up a car to run on the edge such that it may be hard for a rookie to handle. You maybe fast with a less agressive set-up. Even things like tire wear can change if you don't push the car hard in every turn like the last guy. That is one thing I work on with 944 spec guys. They each need to figure out their own set-up as what I like and works for me may be "scary loose" to someone else or "understeer like dump truck". The other thing is that the PO may not have had a good set-up even to start with.
So again record alignment settings and all other adjustable elements and save them just incase you want to back, but don't stay fixaed on that set-up as it may not work for. This applies even if you run the same tires on the same tracks.
#42
If you run at different tracks or even the same tracks at different times of the year you can still be off when you roll off the trailer. If you do your homework you can dial in the pressures just right, but I have seen alot of guys that don't do that. At NASA Nationals in 2009 I ran the test day were I took tire pressures and temps after each of my 5 practice sessions. It took alot more effort to pull into pit lane and check tire pressures/temps rather than go back to the paddock and hop out of the car grab a water. It was valuable to me as I adjusted the car and nailed tire pressures, but some guys don't put that effort in. In that case running a session and setting is much easier if not as precise.
#43
So the goal of qualy should be to get out and cut off 2-3 fast laps and then get off track. If you need more practice time fine, say out. However stil try for fast lap early and let the rest of the session be for practice.
#44
FWIW, I stagger my cold pressures for rear engined Porsches.
Highest pressure at inside front, 1lb. less for inside rear, that same pressure for outside front, and then -1 for outside rear. Different tracks load tires differently, but that should get you close to equal hot pressures....
PS: Friends don't let friends waste stickers for practice. Yell at them if necessary....
#45
Speaking of qualifying strategy.... I always try to be the first one to grid or damn close because I want to get it done on the first hot lap if possible. I know who's faster than me and who's not, and my competitors know where I fit. So I'll point by anyone on the out lap who I know is faster as I don't want them behind me. Conversly, I don't want to be held up so I stay as close as possible to the fastest cars. When we go hot onto the straight I'm then in good position to run at least 1 unhindered hot lap, maybe even 2....
