Good wheel dollies?
I want to get a pair of wheel dollies to move the cup around. Has anyone found one brand to be a lot better than the other ie) smoother to roll around? I've seen the ones from harbour freight, but I"m curious to hear other's experiences.
Thanks!
Thanks!
GoJaks....www.gojaks.com. I've got a set of 4 I use for rolling my car around the garage. Can easily push it one-handed.
Mr. Excitement
HF type is junk.
Zendex (maker of Go-Jax) also makes a low profile / race car version of the Go-Jak. They have 2 small diameter rollers per side rather than one larger one, are wider for wider tires and slide under lower cars.
I found the standard ones are not wide enough and the size that is big enough to fit the tires is too high to slide under the car. I guess you could use the air jacks to lift the car and lower it onto the dollies but that kind of defeats the idea.
