Running r comp tires backwards
got pirelli p zero corsa asymetricos on the 965 and the lefts r wearing more than the rights (only track at mid Ohio)
Can I safely run em backwards? Just flip the right rims over to the left and vice versa... Running the tread pattern backward
I assume it's no issue
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Hmm.. they are called "asymetricos" which would imply a "no" answer.
First is the tread pattern issue. Second could be internal construction issues.
There are other "r" comps that can be run in either direction whose only issue might be reduced effectiveness in the wet, should a tread be showing.
I find the RPM limitations a bit of a problem when running in reverse...
but the only reason a tire is asymetric is due to the tread pattern, shaved or dry you'll be fine...
