It may be that I am just a mediocre driver…….
Actually, in more detail... the point is that the interventions (brake applications) will be boosted, and effectively become more sensitive besides, when you countersteer vs. when you only decrease steering. Furthermore, how quickly they become very very strong will be different from car to car, and from tune to tune. If you get at all crossed-up in a minivan or SUV, you can expect it to come down pretty hard with the hammer, pretty quickly - say, with as little as 5deg countersteer.
When I'm in a sports car, especially in a track mode, I expect it to be much more tolerant of more countersteer... and this is often what you will in particular see when you switch modes, like going to Comp Mode in a Corvette for example.
So yes, countersteering does matter, as does how much. Go out and try it sometime - it's lots of fun! See how hard it hits you in a slide from a given speed if you don't countersteer, vs. a little countersteer, vs. a lot.
In my e46 M3 the DSC costs me more than 3 seconds over a 1:43.000 lap. I find it highly intrusive and the only solution it has is: slow down and understeer. I can't imagine trying to learn how to drive with the DSC on because it would teach that any oversteer slows you down.
To PSM this is a car out of control and about to crash- rather than taking an aggressive line over gators (T3 @ RA).
When my dash was gutted the PSM was "lost" behind it somewhere. The car would cutout every time it lifted a wheel (or 2, or 4). At a track like RA or Barber that means at least 3 times a lap where the car has to then "gather itself"- killing momentum. With the PM switch found and back in the dash, its the first thing that gets turned off upon start up (would like to find a permanent OFF). I forget what your original question was but just leave it off when on track.
"What does PSM really do for driver’s development (learning) past the beginners level?
Are car controls skills obsolete anymore with the advent of PSM or other traction control devices?"
I did shut it off when I was by myself, and then turned it back on when the instructors jumped in.........DE rules......
Thanks for your response, my original questions were:
2. No. Assuming its turned off for the track- same skills as before.
The brain is so much more nuanced than current (or future likely) iterations of street designed PSM systems.
I thought that I might use it when on track in the rain, but it was just so unpredictable. The car was driving me, not the other way 'round. You can't go full lock when you want or need to.
In short, go analog for track and digital for street.
I autocross a more-powerful-than stock 996tt. This is probably the worst light PSM can be in.
PSM slows the car by about 1-2 seconds a 40-second lap in the dry, and in hot slaloms, I have
had it come in like Chinese government sensors, turning the power off for a full second.
If you want to learn actual car control, getting reliable, timely and honest car reactions to
which you can develop and polish your instinctive reactions, you must turn PSM off.
If the environment is such that those car reactions are going to be too new/dangerous/expensive
to risk experiencing and possibly mishandling them, then leave it on.
I leave mine that way all the time, but when it rained earlier this year I plugged it back in and took a 'stay on the track approach' to the race. Qualied 3rd and finished 2nd when the guy I was chasing just ahead of me spun. Was never going to catch the winner, so the strategy worked well the one time I tried it. The PSM saved my butt big time at least once, when I missed my braking point.
In hindsight, or at least now with experience doing this, I might have left it on but toggled the switch off on corner exit and then back on before braking. The big downside in the rain was it did not allow for any wheel spin so corner exit was horrible. Would be cool to mount the switch closer to the steering wheel to do this. Or alternatively I could learn how to drive in the rain, but that's for another thread.
Well, I thought it was a rule, but regardless..........
when was the last time that you "the instructor" adviced "the student" to shut the PSM off?
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Here's my take without riding with you (but Jay did and said you were hauling):
To be fast at NHMS, you have to slide the car a lot. PSM doesn't like this. For beginners, they should be able to drive without having the PSM come on, but by the time they are advanced yellow, it will come in in turn 3. By the time they are in black, it's probably on in most corners some amount.
I bet you had it flash on a little in turn 1 when the car bounced in entry, then came on some for turn 2a. It probably came on a few times in turn 2b when you nailed it. Then, it was on just after turn in at turn 3. Definately on by the time you hit the rumble strip in the middle of turn 3. It might have been on some in turn 6 (the bowl) if you were getting the car to rotate (read carrying enough entry speed). Then it probably came on a few times exiting turn 10 if you carried too much speed down the hill. Finally, if you did EFK right, it came on in the middle of the left onto the front straight.
How did I do?
How did I do?
Good driving, next time bring the 911! I want to ride in that with you.
