Heat cycling the BFG R1
So how do the R1s compare to the Hoosier R6s?
less performance until 5-6 cycles, then they hold out for about 5 more useful cycles. Net is that they are a better value, but will not be what you set your fastest lap on.
not in my experience, maybe the S model (which I have not tried). Definitely not close to new hoosiers, maybe 90%.
For those that heat cycle, curious to know if you have a specific temperature target.
Basic Sponsor
Thanks to the OP. Good info on this thread. Hopefully, this question will fit in as well. What do you guys about switching DOT's from side-to-side to get more wear/performance out of them?
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Herr Unmöglich
This one came back from a couple years ago, and I am just seeing the resurrection.
I ended up running them one session and letting them sit for 24 hours while I ran old tires. I have not tried just running them hard from stickers yet.
I've gone through a few sets now and I agree with others... on our 944's the Hoosier R6 has a slight advantage for the first 2 or 3 cycles, then they are even until the R6 falls off, at which point the BFG still has maybe 6 or 8 cycles left. Most of our guys were on the R6 but the BFG really is a good alternative for club racing and a couple more folks run them now. I do rotate them on the rims around 10-12 cycles to even out wear.
Where's the best place to get the R1s?
