Heat cycling the BFG R1
Changing to the new compound BFG R1 this year from Toyos in the past. First weekend out is a double points weekend, Q1 then Race 1 on Saturday, Q2 then Race 2 on Sunday.
I have 2 new sets of R1's and some really old crappy Toyos that I can use if I have to. Timing will not be ideal but I simply won't have a chance to get the new tires cycled prior to the event. I can run one set lightly in Q1, then swap for old Toyos and save the R1's til Sunday's race for a 24 hour resting period. Or I can just put em on and go for it right out of the gate. Either way it seems I am gonna have some issues on Saturday at the least. Either run hard on uncycled tires, or qualy poorly in Q1 to cycle them and run the first points race on old rubber. Ideas on best approach here? |
Run 'em hard right out of the gate. 2 laps to get all the compound goops off then good to go IMO.
Run 'em.
I was talking to BFG race support last year at NJMP. They told me "Tirerack heat cycling on our tires is not necessary and is a waste of money." So, based on that, I don't think these are as finicky with heat cycling as other tires. |
Originally Posted by Veloce Raptor
(Post 8442460)
Heat cycle as any other "race" tire,one session building up to temp slowly and then let cool slowly. Then let them sit unused for 24-48 hrs off of car before using again. You'll get more life and more consistent tire with doing it this way. Yes they will be slippery until tire mold release is worn off. |
Van, I hate to say it...no, actually I don't hate to say it, because it needs to be said: TireRack heat cycling of any tire (even one that does need proper cycling) is a waste of money, and is not a proper heat cycle.
Viking, that's cool, we disagree. And you may be right, although I believe the R1 is much like the RA1 in this regard, and needs no cycling. Regardless, he does not want to piss away his Q1, so as I said, he should run them hard from the get go to qualify better. |
(Post 8442476)
Ok, now I'll agree with you on that one ! |
Thanks guys... I will be able to properly cycle set #2 on my second race weekend as there will be a practice session.
Because it is Portland in April it will probably end up pouring the whole time anyway and I'll have to run the rains! |
What is the difference in compound meant to be? Or, how do they differ from the previous versions and will they be better, worse, or just different from an R6?
As usual the described improvements are: "Longer life, more grip". Not that any tire would ever be marketed differently!
I think the speed is up in the air. I have read in the past drivers on both sides of the R1/R6 question. Everyone locally runs the R6 so it is a known quantity that I can always fall back on, but I would bet preference depends on each individual car/driver/setup. In my size, the R1 is 25% cheaper per tire as well. |
So how did the tires go without the heat cycle? I am in the same boat, was suppose to go lapping to scrub em off on sunday but got invited to be a second driver in a vintage enduro. Race will be next weekend for my car.
(Post 8442476)
I'm not suggesting your wrong, just don't understand the details of why you might be right. |
I'm an instructor group DE driver and am on my fifth set of BFG R1. I heat cycled the first set on track. Haven't bothered since.
I ran my R1's reasonably for two 30 minute afternoon sessions then i went all
out the next day.I ran two sets of Nittos without heat cycling and they were fine. Cheers Phil |
Heat cycling a tire prior to running it on a track is a beneficial process if done correctly. Also in can be an option for those who don't have an extra set of wheels or time enough to heat cycle them on the track correctly.
And yes - heat cycling done on the track is the best way to heat cycle a tire. Our process would be a very beneficial second choice..... |
Originally Posted by Van
(Post 8442465)
(Post 8442476)
Viking, that's cool, we disagree. And you may be right, although I believe the R1 is much like the RA1 in this regard, and needs no cycling. Regardless, he does not want to piss away his Q1, so as I said, he should run them hard from the get go to qualify better. He also covered how to build heat in tires and a number of other things. I know Van was on the webinar. |
