GT vs Cup HP & weight
#92
That would work! problem is , where to you put the darn things when you want to drive it. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I forgot the CFM, and pressure, but i tested out a electric shop vac that put out 3psi, but barely enough flow to feed a lawnmower engine. gas shop vac might do it (or blower) and two gas blowers. there we go 3psi, 20% HP increase!!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#93
Chris is a pretty good benchmark. He holds a few track records and is a really good driver IMO. But take him over to 997 Cup Car with equivalent gear ratios, and give him a weekend to learn the car and I think he would be faster than he is in his personal air cooled car.
#95
Lifetime Rennlist Member
#96
437hp at 7200rpm? wow, RSRs are making stupid power.
Well, wrong?? I dont think so. the last RSRs were in the 250- 270 range. But, you numb nut, the point is,
317ftlbs of torque is not a "torque" monster!
This is a torque monster!
#97
http://dedeporsche.wordpress.com/201...ets-an-update/
"The naturally aspirated 4.0-liter flat-six gets a 5-hp bump to 455, the full power of which is unleashed at 7800 rpm. Maximum torque is 332 lb-ft, and the powerhouse still redlines at a screaming 9400 rpm"
#99
You dont tell anyone to "knock it off", 4x4 spin doctor!
Listen here tough guy, what part of 317 doesnt equal 332ft-lbs, understand? so, You are wrong too!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Get off the high horse and enjoy the fact that these little porsche motors at 4 liters are making such incredible power. But keep in mind, I still have the dyno of the 2002 RSR with 440 rwhp, which is over 500. so, all the published numbers mean nothing. they are all sand banging
and just so you understand, engine torque means squat! look at the GT2 vet, think it has any advantage with near double the porsches "torque"?
Now, back to the self promotion channel Dave!
Mark
Mark
Mark, honestly...knock it off.
