Has anyone here tried Mobil1 Racing 0W-50?
Team Owner
No oil brand debates, please. I am just looking for actual experiences in track-only cars with this racing oil: http://www.mobiloil.com/USA-English/...ing_0W-50.aspx
Thanks.
Thanks.
i was told to use this and have no issues with it. as i understand it is the only SAE50 officially 'approved' by Porsche.
http://www.sparktecmotorsports.com/98hf24.html
Team Owner
Thanks, but that is for cars that are driven on street & track. the racing oil I am asking about is for non-catalytic converter cars, racing use.
I use it since mine is older flat tappet. The only empirical data I have is my bank account gets smaller quicker than with regular Mobil 1. Other than that, I have no constructive comments to offer...
Team Owner
Thanks. Any oil temp issues in hot weather?
mobil 1 racing is a good oil from what was written about it, like zddp levels at 1800ppm somewhat area, but it just seems to be a bit pricey.
The Penguin King
Thanks.
Thanks.
Thanks.
Thanks.
I looked at the specs for it previously and didn't see any large benefit over what I currently use, it did cost more tho. I should add that I don't think with modern days oils you can see much a difference short term. I do think you can determine more by knowing what is in the oil and then watching oil samples on your motor over a period of time.
As you know, some oils are better for some cars due to a variety of reasons, type of lifter,cam, rocker,cats/no cats,detergents vs foaming,etc etc etc. This will affect peoples experiences and recommendations.
What are you looking at it for ? M3 ?
Team Owner
Yes, for the M3. I use M1 15-50 now, but it is a non-cat track only car. Looking for same high temp protection with less rolling resistance...thanks.
Mike...LMAO! Exactly.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Who carries the 0w50?
Ok, then the next question would be how often do you, or do you plan on, changing the oil ?
And why do you want to change from your current use ? The less rolling resistance won't do much, you might see a few hp at best. It could even result in less hp with the lighter oil allowing lifter bleed down causing less valve opening = less power.
I would speculate that also the lighter weight oil could effect the Vanos performance as well since it is oil fed hydralic operated. I wouldn't think it would if everything were new and perfect but as things get older then it could run a lower pressure and some negative performance effect.
My BMW Vanos experience is limited so I would suggest you consult your BMW tech for proper recommendation regarding this before just taking my word on it.
Can be ordered direct or thru select dealer / suppliers. Mark, OG could probably become a dealer for it if there is sufficent demand.
More info here.......
Team Owner
