Hoosier A6s
Mark, you mention running the A6's at lower cold temps than the Toyos or the R6's.
How many pounds lower?
What pressures are you starting out at with a cold Toyo?
Cold R6?
Fred, with your driving style I'm sure you will tear through any Hoosier. Heck, any R compound tire. I'd advise switching to Michelin light truck tires........and, by the way, pick up your trash in the grid.....
Cold R6?
Ah, Astroman, allowing Hoosier A6's was not a rule change.
There was a rules proposal made last year to ban them but the rules committee did not want to get into the issue of deciding what "DOT" tires were or were not legal for club racing as frankly, there are other DOT tire out there that may have even lower wear ratings.
Where would you draw the line on wear ratings? Wear ratings aren't necessarily the same from one manufacturer to another.
Frankly, I've seen some very quick times turned by drivers on Toyo RA1's, in a well set up car maximizing the performance characteristics of those tires which wear like iron.
Truck tires don't suit the extra low right height of the car these days. Ever since your scolding for throwing out water bottles on the grid, I have installed a proper drinking system in the car - made sense. See u in Atlanta.
Jack, what if the A6s do last longer than we all think they do while still providing that non-negligible performance advantage? Not sure about 15 hard driven HCs, but what about 6 or 8? Yes you end up changing tires more often, but not that more often. Very few people run A6s in PCA CR it seems, but many of them do in SCCA and NASA. It's worthwhile to experiment and document the difference in performance and wear no? I may give it a shot - not sure.
Yeah, i was a little uneasy about running them so low in pressure. keep in mind, this was a team that was running 5 seconds a lap faster, and with 200 more hp, so after measuring their tire temps in the pits after a session, vs mine, i figured i would raise the starting pressures by about 2-3 lbs vs their set up. it seemd to work. they wanted to seem me at 30psi hot, so that is what I eneded up with . the wear patterns and handling sure felt like they were doing their job. so, to contrast. RA1s i start at 28 lbs/30lbs rear to front, and with the hoosier A6s, 24 /26psi starting cold.
Cold R6?
Cold R6?
all out weekends, 30min races with no issues on really hot (fast) cars.
mine didnt even break a sweat, but Im 5-7 seconds slower than the ultra fast guys runing 1:29s at laguna . these are 100 degree days too at thunderhill.
The A series work, i was amazed. Like I said, when I first saw these guys running these tires, i was laughing with everyone else in the pits as we all expected these guys to have their tires explode! They laughed all the way to the podium with new records and race wins. I laughed too, when I started grabbing up their scrubs and racing on them with my fairly powerful, heavy racer.
I used them for an hour race with no issues too.
I don't know...was only disputing your post that they are only good for 3 laps of qualifying. I doubt they are much different than any other fast R-comp or slick. The guys who want to be fast will switch them out every weekend, day, or even race, and the guys who don't will run them until they cord.
For reference, I have run A6's, along with R6's, and R100/80's on the same, fairly warm, weekend at VIR, so I have some experience with how they last/wear.
I've posted it here before...don't remember right now and I don't have the data in front of me. Probably not too hard to find with a search.
Edit: found it https://rennlist.com/forums/7495042-post11.html
