JRZ Double adjustable shocks/struts for 1965-89 911
I bought this set up from Steve Alarcon last June.
I never used them.
Here is the the original ad.
http://forums.pelicanparts.com/porsc...le-shocks.html
JRZ Double Adjustable Shocks for 1965-1988 911
Front Struts has raised spindles 17 mm.
Steering Arms Modified for Bumpsteer 19mm.
De Cambered Spindles -1.25 Degrees.
Spindles RSR Gussets.
These Front Struts allows for a 15" factory fuchs wheels.
The negative cambered spindles are for track use, camber
range should be -1.4 negative to -2.75 negative.
Front and Rear Shocks has treaded bodies for coil over springs.
Rear Shocks have uni-ball mounts with ERP upper mounts.
These JRZ Shocks are in excellent condition.
$3,800.00
I also have Glenn Sanders torsion bars for these JRZ's.
Torsion bars are for pre G-50 911's.
Glen Sanders front torsion bars 24.5mm
Glen Sanders rear torsion bars 35.0mm
Modified front torsion bar levers(welded and reinforced)
Teflon torsion bar sleeves (for front bars)
$845 for Torsion bar package
If you buy shocks/struts and T-bars I will sell for 4500.00 and include shipping to Cont. USA.
I want to wait until the JRZ's sell to break up package.
I never used them.
$3,800.00
I am interested in the JRZ suspension kit. However, I would like to use them with coil springs. I know they are available as a kit in coil overs. How much more would it cost for me to get the springs, etc. to proper;y convert them into coil overs. Thank you.
Inquiry
Are the JRZ's sold already? Are they valved for street or track use? Thank you.
I never used them.
$3,800.00
I never used them.
$3,800.00
