996 build
Old 02-23-2011, 01:16 AM
jrgordonsenior
jrgordonsenior's Avatar
You should weigh the mufflers and cats. IIRC they're around 85 lbs. together....
If for any reason you have the motor or trans out remember to replace the AOS. It's a $110. part....
Old 02-23-2011, 08:40 AM
AudiOn19s
AudiOn19s's Avatar
Is that Dan's (Fissionx) old car? Should be a solid starting point.
GT3 sway bars are an easy swap since the adjustable drop links are already present and are an easy, worthwhile upgrade.
Andy
Old 02-23-2011, 09:01 AM
utkinpol
utkinpol's Avatar
Originally Posted by fletcherdave
Jr, I was able to make out some writing on a sticker on the damper body. I was able to make out "996 GT3". Lots of numbers stamped on the damper body as well along with "made in Germany", so I'm going with Sachs....what do you think?
On a side note.....I am ordering the LN Engineering deep sump kit and read it increases the oil capacity by 5 quarts!! A small spacer increases that much?? I believe the car already takes 10 quarts so I will need 15 quarts??!! I wasn't able to locate a phone number on the LN website.
regular spacer increases capacity by half qt.
for suspension you can get it all from tarett - LCAs, rear toe arms, front fork arms
http://www.tarett.com/items/996-997-...kit-detail.htm
http://www.tarett.com/items/996-997-...010-detail.htm
http://www.tarett.com/items/996-997-...lnk-detail.htm
and optionally dogbones. Tarett uses ERP rod ends - best on the market.
they also have this:
http://www.tarett.com/items/996-997-...996-detail.htm
x51 oil pan and GT3 sways are cheaper from suncoast.
Old 02-24-2011, 01:45 AM
fletcherdave
fletcherdave's Avatar
Audi, I bought the car from someone named Dan In North Carolina.
Old 02-24-2011, 08:32 AM
AudiOn19s
AudiOn19s's Avatar
Yup...good guy.
Where are you in Ohio? There's a couple few nice early Aero kit cars like your floating around columbus. Sadly I no longer have mine.
Old 02-24-2011, 12:54 PM
karlooz
karlooz's Avatar
you should also do the x51 oil pan which includes a better designed baffle
Old 02-25-2011, 09:16 PM
fletcherdave
Audi,
Here's the pic of my last race car. The boys at Motorkars in Cbus built it.....well most of it anyway.
Quick Reply: 996 build
