Coolsuit drain fittings
FWIW, I bought 2 extra male fittings that I plug into my shirt at the end of the day. I cut off the ends to open up the air flow and this allows the shirt to drain. I also blow some nitrogen thru the lines. When washing the shirt I unplug them, but reinstall and leave the tubes open in storage....
It might be nice to attach a 3 way valve on one of the shirt ends for a rapid flush and cleaning.
The Penguin King
This is a good idea John. The males just plug/slip over, attach to the shirt. I have females on my shirt and the males are attached to a permanent bracket I had fabricated. I guess these extra males w/cut off tips only allow gravity flow drainage? I think the females auto lock when not attached to the males.
There are three different connectors for the FAST Cool Suit system. A threaded female fitting that screws into the cooler, a barbed female fitting that is on the end of the hose where it connects to the shirt and a barbed male fitting that is on the other end of the hose (where it connects to the cooler). The respective Colder Products Company part numbers are: PLCD10004, PLCD17004, and PLCD22004.
I ordered them from quickcouplings.net but they are available elsewhere including Grainger. You can purchase just one of the male fittings and use it to clear the hose connecting the shirt to the cooler. Simply plug the hose into the cooler and attach the male fitting to the other end and blow through one side then attach to the other side and repeat.
I purchased one each of the female fittings (one threaded and one barbed) to use to drain the shirt. That way I had a replacement part for both of the female fittings. Alternatively you could purchase two of either type but I figured it was better to have a spare for each in the event of needing to replace them.
As always, no guarantees (expressed or implied), YMMV, not responsible for any injuries resulting from following the above advice etc. etc.
Also, no lattes were spilled during testing and the advice above is worth exactly what you paid for it.
