Race wheel suppliers
Old 09-26-2011, 06:30 PM
  #181
analogmike
analogmike's Avatar
Originally Posted by winders
Mike,
Shouldn't that be:
"No need to corner balance the car when changing tire sizes as long as relative ride height, front to rear, does not change."
You could change tire sizes, have the left and right side tires be the same on each axle, and change the relative ride height front to rear. Which could necessitate a corner balance change. Right?
Scott
No, if you don't mess with the suspension like Gary did, the corner balance will be perfect. Even if the car's rake changes by a few inches the corner balancing will still be on. It would be nice to lower the car though if you have more clearance with the smaller tires, then you had best corner balance.
Old 09-26-2011, 06:38 PM
  #182
paradisenb
paradisenb's Avatar
15 x 40, 45 or 50 may not require R&R of TBs. I guess the 35 leaves the car higher than optimum. What I want is to be able to run 15s in historic racing (Toyo tires) and 15s in PCA or NASA (Ho Hos) w/o having to change ride height or anything. Just want a bolt on solution. Will this compromise the setup with Hoosier 15s?
Old 09-26-2011, 06:41 PM
  #183
winders
winders's Avatar
Mike,
If you lower the front of the car 2" more than the rear with a tire size change, does that not change how the weight is distributed? Maybe not a lot, but it does change, right?
Scott
Old 09-26-2011, 06:48 PM
  #184
Astroman
Astroman's Avatar
Mike,
Scott
I think it changes the front/rear percentages but not the cross weight percentages.
Old 09-26-2011, 06:50 PM
  #185
KaiB
KaiB's Avatar
Might want to check with Kibort on this one.
Old 09-26-2011, 07:17 PM
  #186
winders
winders's Avatar
The cross weight percentages would change as well unless each wheel carried 50% of the weight on its end of the car.
It's not much of a change, but it is a change. Not likely enough to worry about.
Scott
Old 09-26-2011, 07:42 PM
  #187
Astroman
Astroman's Avatar
The cross weights would change but the percentage should not.
For example, lets make up a perfectly balanced 2000 lb car with 500 lbs on each wheel:
F 500 500
R 500 500
Then change the ride height and rake to shift weight towards the rear:
F 400 400
R 600 600
The cross weight percentage in both examples is still 50% of the total weight.
Old 09-26-2011, 08:08 PM
  #188
winders
winders's Avatar
F 500 500
R 500 500
F 400 400
R 600 600
Your example is the exception I mentioned in my previous post.
Pick a car with these weights:
F: 500 470
R: 750 720
Change the rake evenly on both sides so 100 lbs is shifted to the front wheels. What happens with the cross weights which were both at 1220 lbs.? The weight transferred to the front is split based on the front percentage (51.5/48.5) and removed from the rear based on the rear percentage (51.0/49.0).
F: 551.5 518.5
R: 699 671
LF-RR: 1222.5
RF-LR: 1217.5
Subtle, but different....
Scott
Old 09-26-2011, 08:24 PM
  #189
analogmike
analogmike's Avatar
If you raise the front of the car by a foot it won't barely change the ft/rear distribution. It WILL change the handling, but not because of weight transfer, because of geometry. You can do the math (I have, just calculate the C of G position and see how it changes by raising one end) or try it with scales and wood.
So the answer is, no you don't have to corner balance your car when changing wheel sizes. Gary, you should be able to find a good compromise to run with both setups though you CAN just crank the TBs a certain amount the same right and left and be close enough. I do that when I remove ballast for vintage racing.
Old 09-26-2011, 08:58 PM
  #190
winders
winders's Avatar
Mike,
I understand and agree. I actually hadn't thought about how much you would have to raise or lower one end to get a significant change. I only got as far as thinking that changing the rake would change the weight distribution so it would change the cross weights.
Scott
Old 09-26-2011, 09:24 PM
  #191
analogmike
analogmike's Avatar
Most people think that, even some really good pros.
Old 09-26-2011, 10:03 PM
  #192
paradisenb
paradisenb's Avatar
Interest analysis. I will try this when I test mount a set of 15 inch Fuchs. Switching from 17s to 15s and back. Only draw back is the tires on the 15s are Toyos 235-50-15 I think. I won't be able to test with 275-35-15s.
Old 09-27-2011, 11:41 PM
  #193
sig_a
sig_a's Avatar
[QUOTE=Astroman;8897534]I have wondered the same thing. However I hope that I'll only require 5th gear (with 15"s) in the same locations that I currently require 5th on 17"s (back straight Atlanta, back straight M-O, back straight at the Glen, all 3 straights at Road America). I may need 5th on the front straight at Putnam on 15"s (which would be no big deal).
I was recently at Putnam with KYPCA on 15" v710 kumho 225x50 at 23.8" diameter. I up shift to 4 at tower, up shift to 5 at bottom of dip. Downshift 5 to 3 between 200' and 100'. Relearning shift points changes approach over entire track. Square setup thrilling, and could use more tire at rear.
Quick Reply: Race wheel suppliers
