Tried Hoosier slicks this weekend for 1st time.
They're taller than the normal R specs Henk so you have to choose the width of the tyre carefully to allow clearance...if that makes sense.
I'm in the middle of it. Just received the new Goodyear RS in 245/35x18 and 275/35x18, with a treadwear of "40" going to fit them tomorrow on the car and check for clearance. Noticed that this 245 is 2inch wider then the current 235 NT01 ! Then the race of the year coming up 12/13/14 November on street circuit. http://www.bangsaengrandprix.org/index_eng.html
here's some footage I use to learn the track. http://www.youtube.com/watch?v=6hDDiHp3duA
will let you know.
H
thanks for the vid.
will let you know.
H
thanks for the vid.
in my 2500lb BMW (2700lb with driver) I like 31-32psi hot front, 30psi hot rear for the R80/100
Heads up... back in the day when I first tried Hoosiers on my 951 I drove to an AX on them. They were brand new tires. Flat spotted them in the mid afternoon. On the very next run, blowout on one of the flat spotted front tires. Years later my wife spun on track on a fresh set during a time trial. Flat spotted one of the fronts. It had 4 heat cycles on it-- pretty new tire. I checked the tire and the flat spot went all the way to the cord. Back then the tires had no steel belts... that may still be true. I suggest a careful exam of all flat-spotted Hoosiers.
will let you know.
H
thanks for the vid.
will let you know.
H
thanks for the vid.
I'm not really a fan of road circuits as a spectacle. They do look very testing and not one to make mistakes on with all the barriers.
Good luck!!
i bought my tires as used takeoffs, so I took what I could get. they were a combination, mostly R100s. obviously they already had a few heat cycles, but I still thought they were good and I ran my fastest times on them. I couldn't tell any difference b/w R80 or R100
Sorry, the street legal sticky tires-- I now see from context that you may be talking about full slicks. I have run the Hoosier bias ply full slicks, but not their radials. With any of these tires, as you know they like to repeatedly flat spot at the same place, and I like to check to make sure that they are not corded in that spot. When the street legal tires came out, many were caught out by the fact that they only had fiberglass belts and were relatively fragile compared to other street legal sticky tires. I saw a lot of cars have blow outs in these early days when they were first introduced. I run Goodyear slicks (have done for 9 years) and my experience with the the Hoosier street legal sticky tires with my 951 has helped me respect the fragility of the Goodyears in terms of flat spots and things like rocks (sharp rocks can easily cause punctures).
I wonder if tyres can't be shaved to reduce or remove a minor flat spot?
