What is the coldest outside temp. you can run MPSCs in?
I still have a few trackdays left and was wondering what the coldest outside temperature would be before you should stop running MPSCs. It's about 60 degrees were I am and getting colder every few weeks.
I run them at 36psi hot in warm weather, is there anything I should do differently when running them in cooler weather?
Yes - make sure you warm 'em up good before you lean on 'em.
Moderator
Depends on which Cups you are talking about. If "real" cups then I'd say not to go below 40 as they are like hockey pucks. If the Porsche N-rated cups, then pretty much any temperature. I've run those as cold as 28 degrees without any trouble (love those early spring / late fall days at Lime Rock).
the real one's I only use in the summer months, I suggest Contis for the 'shoulder' period before and after winter. For me the cut-off temperature is 6°C that is 6*(212-32)/100 +32=42.8°F (any chance of switching to SI this side of the next millenium).
Its not just the temperature, its slippy things like Fall leaves on the road, and nasty damp patches, and the interaction with ABS. If you want a nightmare experience, try brakingwhilst approachimg a junction covered in slippery leaves.
On the plus side, three sets of wheels anhd tyres is 50% more cool than two sets, or to put it another way, you need twice as much rack space...... 'Look at THAT rack!.......
R+C
R+C
I have run them with frost on the ground but those first few laps are hairy. Like it was said above, just get them hot before you start pushing them. Also, watch the pressure as you get them hot - I had big swings in pressure that day...
R+C - I wish, I have given up on us ever changing over.
R+C
I try not to us them below 60 degrees! It is very hard for me to get enough heat into them to make them stick. "Hairy" doesn't begin to describe it ( 55 degrees at the kink at Road America at 105 mph, I thought I had enough heat, but guessed wrong. I survived, proving it is better to be lucky than good) Anything below 60 and I use Hoo R6.
I start at about 25 lbs cold even on warm days, What do you start them at at 40 degrees? How many laps does it take to get them to stick, and how many laps are left in the session (or race)?
Still plays with cars.
Up here we see temps very near freezing in the fall. I have run real Cups in those temps. No problems driving to the track - just drive prudently since the rubber is essentially frozen. On the track, a few laps to get heat in them and they are fine. FWIW on the 996 GT3 I used 32F, 34R hot pressures. Anything above 35 lbs and the tires felt greasy no matter what the air temperature.
Best,
Best,
R+C
R+C
On warm days I start with 29psi cold tire pressures and keep bleeding the air out of the tires till they are a solid 36psi hot tire pressure.
Best,
Best,
I agree with Bob on the front pressures and for a little lighter car 964/993 I run 36psi rear. You need to induce excessive slip angle on these tires during your warm up in slower speed corners eg 50 to 70mph apex speeds. They warm up nicely then. Typically 8 lbs lower starting pressures.
I would go with the staggered setup. Bob has alot of experience so start with that target. Dr.J and Collin had them dialed in very well some years back when they ran them using the staggered pressures ( I believe they were using 32/36 on the advice of a Michelin Engineer). This tire likes to be hot and it is almost impossible to get them too hot in the cooler weather. Bring a pyrometer to the track and follow the Michelin performance guide for track temps. I think it is a really good learning tire since it has a variety of behaviors during the warm up phase.
