corner balance vs ride height/rake
#31
We built some stands for the scales that are a few feet off the ground and we do the balance with the car on a suspension lift. Makes it a lot easier to adjust everything.
If anyone needs a set of the Longacre aluminum ramps to go with the adjustable pads pictured above I have some I never use and would like to sell. I'll take $300 for them, half the price of new ones:
http://www.longacreracing.com/catalo...?id=61&catid=2
#32
One of the biggest misconceptions about cornerweights is that the weights are completely determined by height, If you turn it around and think of corner weights as pressures it makes it easier to get your head around... And it's the only way to get it really right, nice writeup mike.
#33
but do your ride heights change when corner balancing?
email me at jmitro2000@yahoo.com.
thanks
#34
Basic Site Sponsor
Basic Site Sponsor
It depends on how stiff the springs are. With cup car stiff springs, it only takes a couple of mm to make quite a change.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#35
The springs are a factor, but the most dominant is the motion ratio, right?
Just thinking out loud. If you are already at equalibrium, does it really matter all that much what the spring ratings are, unless you start twisting the chassis.
#36
#37
Basic Site Sponsor
Basic Site Sponsor
At a rest, it still makes just as much difference. If you have a 1500 lb spring, then you will only need to move it 1/3 as far to affect the same weight change as if you had a 500 lb spring. Or to use J Richard's thought process, it will create 3 times the pressure for the same amount of movement.
