Motorized Trailer Dollies
We are considering doing a little expansion work on the garage which will make manipulating my trailer around even more difficult on our lot.
With the expansion (simulated with cones), I can still get in and out of our driveway (a bow shape) with the trailer. So that's good.
Loading and unloading will be tight but doable. There is a slight incline on our lot which makes moving the trailer with my hand dolly difficult. OK, so I'm a ***** and can't push the thing around easily. With the car on the trailer, I can't budge it.
I've been doing some research on the various powered trailer dollies out there. They use car batteries, AC, or gas to power them. They range in price from about 800-2200.
Does anyone here actually own one of these. I saw an old post from Ken Gorman that he used an ATV. If I did that, then I'd have to have a secure place to park that!
Please don't tell me I need to hit the gym. I'm well aware of that. Then again, having extra weight should help push the damn thing around.
Not sure if this will work with your configuration, but if you unload the car and back it into the garage, then maneuver the trailer by hand to in front of the car, then hook up the trailer to said tow vehicle, then drive car onto trailer, then back trailer into garage, you're done.
Or, you could buy the dolly and spend the time saved over a beer or 3.
You have room for a trailer in Cambridge?!
Dave:
Another thought would be a simple garden mower/tractor you put a ball mount on front or back and off you go. If it was a warehouse you could use a forklift
Super Moderator
Needs More Cowbell
Needs More Cowbell
^ + 1
Any vehicle with a front hitch makes it easy to accomplish what you need to in this case.
Be aware that some of the motorized dollies are designed for flat/zero grade applications in dry conditions.
Add an incline or sand/salt/leaves/water and it can end rather badly....damn you Sir Isaac Newton.
Belmont is literally across the street from me so we're sort of Cambridge suburban! Our front yard and driveway takes the Featherlite no problem.
I think I'll still keep the trailer outside, especially if I go enclosed. I like the idea of a beer when moving the trailer though.
^ + 1
We have a slight incline now but with our proposed project, I might flatten out the whole front and make a courtyard.
Dave,
I posed this question some time ago. We ended up just purchasing a cheap-o ATV off of Craigslist for about $1k and use it to tow the trailer. We just use a simple harbor freight dolly and hook it to the ATV so the ATV does not take the hitch weight directly.. Not awesome, but good enough and we use the ATV at the track events.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Never thought of a snowblower, but I would have to wonder how well the friction type clutches would hold up in this application.
Of course make sure you size your trailer mover for an enclosed trailer...it's just a matter of time you know
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Snowblower may or may not work... Back in the day when my son started to leave non-running vehicles in the driveway for extended periods of time. I was able to push them around the driveway with the snowblower in the snow, where I could not move them myself. Our driveway does not have much of an incline, but I was pleasently surprised at how well this actually worked.
It was my wife who suggested that we expand the garage and she likes the idea of an enclosed trailer. Geez I married well.
