"Hero to Zero" or "Surviving my First Fire"
[QUOTE=disasterman;7655070]Since I am relatively small, 5'5", 145 it's possible...QUOTE]
Jim - Sorry to see those pictures, but glad that you're OK... I'll start looking for a replacement engine! If anyone knows how to deal with the aftermath of a fire, it's you!
Oh, you must have been wearing your 3" heels when you got measured
Disasterman,great avitar !
Mr. Excitement
Actually, the main reason for the spare/wrecked 951 was the spare motor, it runs, has good compression and about 84k miles, we will take it apart and freshen it completely while upgrading the cam and having the head reconditioned and improved. At the same time, I will dry ice blast the bottom of the car, remove the balance of the sound deadening that has not burned off, install my new hardened S2 ring and pinion plus some other select bits (sako can, 3 piece cross member, manual rack) and it will be off to the races with a new and improved race car. I may have to get a spec Miata to shake off the racing jones though.
Doc - My next move is to use surgical tubing to secure the harness out of the way like an endurance car.
Basic Sponsor
Thanks for sharing and glad you are ok! Consider changing you user name. Blessed-man or safe-man or lucky-man. A fire is a racers worst nightmare.
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Thanks but "disasterman" is my moniker because my business is Disaster Restoration in the states of Michigan, Wisconsin, Illinois, Indiana, Florida and wherever there is a hurricane.
Basic Sponsor
The surgical tubing is a very good idea.
It will be interesting to see Roy's video from right behind you!
How is your car restoration comming? I am going to practice getting out. 8 sec out the door but doubt I would fit out the window. 6'1" 240lbs
