DE Brake fluid and Tires
If you are doing many DE events should you be changing brake fluid sooner than 6 months and if yes after how many events?
Michelin Pilot Sport Cup how many DE track days will I get from them?
Thanks for the help.
Brakes - Depends on the type of fluid you use, how many events, and what level you are.
Tires - many here run PSC's that should be able to be fairly accurate but that will depend to a degree on the level of driver also.
Use Castrol SRF or Endless RBF 650 and you'll only need to bleed occasionally, if at all. I race my cars and do a bleed after 10 races. It is $$ up front but less expensive over time if you do a lot of DE's. These fluids also give an excellent pedal feel. For tires I'd use Toyo RA 1 or Michelin Pilot Sport Cups.
with superblue if it isnt ready for a change after 3-4 events then you arent using them hard enough
ATE is (in my mind) the lowest end of track-ready fluids. I use motul RBF600 or 660. SRF is superior in wet boiling point which is why it lasts so long, but you definitely have to pay for it. If it is just DEs and not racing then maybe SRF is the way to go and then you dont have to worry about bleeding fluid.
Like others have said, if you don't mind the cost, then SRF is worth it. The Michelin MPSCs will last along time and are great for DE use. Same with the Toyo RA1s.
WOW, I'm just a DE'er but NEED to change the ATE blue ever weekend... (sometimes each day)
do others get that kind of life out of their brake fluid?
(and it takes 2-3 bottles to get a complete flush? right?)
I've always used Ate blue and gold and have never had a boiling or performance issue. If I feel the need to spend more for fluid, I'll just give the guy another $15 for another bottle of Ate!
Since I swap tires for a DE, I routinely do a quick bleed (not a flush) before any DE. If you are a DIY'er get a Motiv Power Bleeder ($50) and bleeding becomes as easy as putting air in your tires (once your tires are off). I've never had a brake problem, so maybe my frequency is overkill, but I can't imagine anything more bothersome than losing brakes at speed.
See, this is what I don't understand about people using ATE blue and having to change fluid all the time. I buy one bottle of SRF at the beginning of the season for $70, flush the system and never bleed or change again until the next season, and I have a heavy and fast car. Besides the hassle of constantly bleeding the system, the cost of the many bottles of blue costs more in the long run. IMO, it's a no brainer.
I highly recommend you to get you own bleeder kit as it is a simple job and saves ton of money to do it yourself. get pagid yellow brake pads for sure as well.
I did 2 DE events and 5 autocrosses so far this season, after this weekend I will bleed it out as at lest event I just felt how I was flooring my brakes more often than before, so, it is time. But I have inexpensive fluid - motul 600.
I just bleed frequently because it seems like a good idea. I could probably go a full season, but it's just that easy to bleed. Use doesn't degrade brake fluid as much as time does.
Same experience here as Landjet. Heavy car (2002 996TT X50), put SRF once a year, never worry.
No issues whatsoever, don't even know what brake fade feels like. Worth every penny.
Only thing "Super" about super blue is the super way it stains your reservoir and turns your new fluid aqua until you pump about a gallon through the lines! People think SRF is crazy expensive but need to understand that the $75 bottle is double the size of everyone elses so to compare it's $37.50 compared to the $24.00 I pay for Motul 660 (IIRC). Not too big a deal in the scheme of things...
