Help- tires creeping around the rims
Old 05-19-2010, 12:33 AM
  #31
fatbillybob
fatbillybob's Avatar
Bead sealer is like black rubber cement and it is slippery. So mount tire with it wet just like using soapy water. Seat bead and wipe off excess. It will dry and the tire will not move. I use brake cleaner on the beads to clean them before i mount. Cheap hairspray is cheaper at Target so I use that unless I got a stuborn tire. I got my own machine so I flip and remount tires all the time. I never balance them I only balance the wheels. My tires never move and currently I'm on hoosiers for my class in a 3200lb car and we brake hard. 1 day rotor life and 2 day pad life and 4-6 races on the calipers are all we get on SCCA T1 vettes and tries do not move. I use a combo of CCW's and stock OEM wheels so there is nothing special there.
Old 05-19-2010, 09:13 AM
  #32
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
FBB, if you only balance the wheels (like I do) why worry if the tire moves or not?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 05-19-2010, 11:11 AM
  #33
Darren
Darren's Avatar
Yah I like that idea!
Old 05-19-2010, 11:43 AM
  #34
kurt M
Mr. Excitement
kurt M's Avatar
I watched a set move so bad that one of the rears spun the rim on the bead and melted the bead.
In Landjet defense racers don't drive the same tires on the street. An out of balance wide low profile tire on a street driven 911 is a real chore. It makes the Madagascar cinammon sprinkeled lowfat foam on your Starbucks fall and mix in the the coffee.
Old 05-19-2010, 02:49 PM
  #35
m73m95
m73m95's Avatar
I would give my left nut to have a car powerful enough to have this problem
Old 05-20-2010, 12:11 AM
  #36
fatbillybob
Well, because it is so easy to control and i do not think tires should move on wheels. For us in SCCA races are won and lost on tenth's and i need everything I can get. If a tire slips on every deceleration and acceleration that is motion you are not controling. I have a hard enough time with all the other issues of racing just using hairspray or beadsealer to mount is just plain easy since I own my own machine.
Old 05-20-2010, 01:56 AM
  #37
Darren
Darren's Avatar
I'm not sure the rotation is enough to affect your lap times. Man those SCCA guys take themselves way too seriously
Old 05-20-2010, 02:56 PM
  #38
Land Jet
Land Jet's Avatar
I bought a can of X-tra Seal and will give it a try.
My next set of tires I'll try the Nitto NT-01's.
Old 05-20-2010, 08:00 PM
  #39
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
Then it becomes an alignment issue.
Old 09-02-2010, 10:26 AM
  #40
007DT
007DT's Avatar
Sorry to dredge this old thread up, but I wanted to get some clarification on mounting an R-Comp (Nitto NT-01) and then running on it within ~ 12 hours or so..
From looking at the above posts it seams the consensus is:
- Balance the Rim w/o tire
- Clean the rim and tire of any soap, etc.
- Mount with HairSpray (Is there a better brand than others? and/or Aerosol over spray)
- Balance again with tire on rim
- Inflate to 40psi and leave for as long as possible
My final question is probably obvious, but I'd assume there is a less likelihood of having rotation issues when these are the rears being mounted and ran w/i a relatively short amount of time.
What say you?
Old 09-03-2010, 12:32 AM
  #41
mdrums
mdrums's Avatar
I fixed my tire creeping issue by having my CCW rims bead blasted and the tire mounted dry.
Quick Reply: Help- tires creeping around the rims
