AIM interface with M48 (running it? got a question)
If you're running an AIM (I have Pista) dash interfaced with MoTeC M48, have you ever had a problem with dash locking up when you flip screens using '>>' or 'view' buttons? I've narrowed it down problem disappears when i disconnect M48 RS232. Dash works just fine if you do not change screens...
Working with the AIM guys, but figured I'd check to see if anyone else has seen this.
Check all the grounds. Motec is sensitive to any ground faults. Check the Motec data for errors. I run a pro dash with Motec and don't have that issue. Any time I have ever had Motec gremlins it is in the ground.
Regards
TSheehan
Regards
TSheehan
