Battery Grp Buy
Battery Grp Buy
Selling brand new Optima battery, shipped direct from the factory to you at no additional cost.
You can place an order by making payment to Paypal acct : decals944cup@aol.com. Upon payment receipt, I will mail you a certificate issued by Optima for one free battery. This is a limited time offer not available. This is a manufacturer's promotion only and is not available thru retailers and distributors.
Measure the battery in your car(s) and select the Optima battery that best meets your needs from their spec sheet:
http://www.optimabatteries.com/optim...wtop/specs.php
http://www.optimabatteries.com/optim...dtop/specs.php
All proceeds go to benefit the 944 Cup series. Thanks for yur support.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
On their vehicle lookup for application, Porsche isnt even listed. LOL.
I am interested in this buy, what type do folks favor, Red or Yellow?
Selling brand new Opitima battery, shipped direct from the factory to you at no additional cost.
You can buy any red or yellow Opitima Battery for $115. You can place an order by making payment to Paypal acct : decals944cup@aol.com. Upon payment receipt, I will mail you a certificate issued by Opitima for one free battery. This is a limited time offer not available. This is a manufacturer's promotion only and is not available thru retailers and distributors. Supplies are limited.
See the Opitima web site for the various batteries available:
http://shop.optimabatteries.com/prod...19.54056.0.0.0
http://shop.optimabatteries.com/prod...19.53659.0.0.0
Proceeds go to benefit the 944 Cup series. Thanks for yur support.
no chance of getting a blue top ? (marine)
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Thanks Steve, i will look into the red one. Next question, which group number do I fit for a street car? 993 to be more specific.
Then, where is their dealer or retailer directory?? -- I looked on their site and I didnt see such a listing.
My 9993 track car has a yellow top battery; let me know if you need any measurements and I will try to dig them out.
Optima replied to my query about 993 batteries as follows (I was so insulted):
Unfortunately, Optima does not offer an exact-fit replacement battery for your 1995 Porsche 911. You can measure the dimensions of your existing stock battery to see if there’s an Optima that will work for your vehicle. Below is a link to the product specification page where you can find exact dimensions for all Optima batteries:
http://www.optimabatteries.com/optim...etop/specs.php
Alternately, you can check the internet enthusiast forums for your vehicle to see how others have done custom applications with Optima batteries.
RedTop: Use this for normal engine starting where an alternator immediately monitors the state of charge and provides energy to the battery whenever it is needed. This would describe most stock vehicles.
• Automotive & RV under-hood starting
• Heavy equipment where starting is primary function
• Diesel powered vehicles with no aftermarket electronics
YellowTop: Use this when electrical loads are higher than average, or when the discharge cycle is more than typical engine starting, such as vehicles without alternators. This also includes vehicles with significant electrical loads that may exceed the average alternator output (for example aftermarket audio system, GPS, chargers, winch, snowplow, inverters, drag cars). This can also include vehicles that have a lot of electronics from the factory, such as a mini-van with power sliding doors and a DVD player, especially if the DVD player is used when the engine isn’t running.
• Racing vehicles without a charging system (alternator or generator)
• Dedicated drag racing vehicles
• Diesel powered vehicles with aftermarket electronics
• Car audio/video applications exceeding 250 watts over the OE system
• Vehicles or heavy equipment with inverters, hydraulics, winches or other accessories
• Electric vehicles
If you are using an Optima battery in a custom application, it is important to consider the following:
• Hood Clearance – There should be at least ¾” clearance between the top of the battery terminals and the underside of the hood.
• Trunk/Interior Mounting – If your battery is mounted inside the passenger compartment or trunk (common in many European makes) the battery must be vented to the outside of the vehicle. Optima group 27, 51, 78, 34C, and 31 batteries all have ports for connecting a vent hose.
• Side Terminals – Optima 34/78, D34/78, 75/25 and D75/25 batteries have both top and side terminals. If you are using one of these batteries in a vehicle that uses the top terminals, it is important to ensure that the side terminals cannot come into contact with anything metallic (for example, the firewall or fender well), thereby causing a short. We suggest keeping the post protectors on the terminals you are not using. Do not connect a winch to the side terminals.
• Battery Modifications – Cutting, drilling, trimming or otherwise modifying your Optima battery may present a safety hazard and will void the warranty.
• Mounting – Your Optima battery must be securely mounted. The terminals are not intended to be used to secure the battery. Using the terminals in this way will damage the battery and void your warranty.
• Heat – Protect your battery from high heat, such as turbochargers or exhaust manifolds
Suggest measuring the batt currently in yur car and use that as yur guide. Also considering top or side posts. Some racres prefer the lighter models.
Batts are delivered direct to address provided by u so no need to find local retailer.
With better rechargeability, the yellow top is better for modern accessory-loaded vehicles. The YellowTop can repeatedly bounce back from deep power drains to full energy capacity, so it can power plenty of electronics and still start you up time after time. Faster recharges.
