why not shuffle steer?
#31
So, basically, the decision of when to remove your hands from the wheel is based only on how much you have turned it, versus how much more you feel you will need to turn it? 180 degrees with hands at 9 and 3 is not necessarily unsafe or irresponsible?
#32
No shuffle steering. Get closer to the wheel and buy a smaller wheel if you feel that you are forced to shuffle steer...
#33
NASA Racer
I shuffle steer in rare situations. My rule of thumb is after several laps/attempts at a corner if I feel like I am really reaching and my arms are crossed up and I'm holding on with a death grip I'll shuffle steer. The only way you can properly feel the inputs from the car through the steering wheel is if your arms and hands are relaxed and you have a light grip on the wheel. In addition, you take away options if your body is in a position that you are at the limit of of steering travel.
This particular topic gets a lot of heat when it's discussed, but if you wade through the thread I posted earlier you'll see several videos of Senna, Schumacher, etc. who shuffle steer. Part of the problem with these threads is in the definition. Somebody who moves their hands all over the place on every turn are referred to as "shuffle steering" meaning it's their general technique for any corner. My definition is above - sliding your hands on the wheel in preparation or during a corner that requires it under a defined set of circumstances. Shuffle steering should be a fallback technique not the primary technique, but don't be afraid to use it when necessary.
If you are new to this sport, learn it under the supervision of an instructor. He/she will be able to observe your technique in a given corner that is giving you trouble and help you to learn the technique. It is very specific way of moving your hands on the wheel, not just lifting and placing.
#35
I don't know anything, but this was the most important adjustment for me. No more leaning forward to stretch to complete tight turn arms akimbo. However, I do let the wheel snap back at exit by releasing and grabbing at completion.
#37
NASA Racer
NASA Racer
starts about the 1:30 mark and gets wild at about 2:15 - it's actually pretty crazy what he does with this car and how extreme his steering movement is
http://www.youtube.com/watch?v=gmwaCjLg8MY
#39
same.
#43
Another reason to love NASCAR, interupting Sebring, it limits coverage of some terrific real driving and racing resulting in us beating up on some poor guy who needs a little help in droving technique. Good thing was it looked like the eggs didn't break as he went farming. Give the guy points for not texting while driving.
#44
Dependent on car,or better said, steering ratio of car, and corner of course, shuffle may be necessary.
Best shuffle steer driver I've ever been with was Vic Elford, of course with his rally experience I would expect no less. He never said a thing about my shuffle steering either, good nor bad.
#45
I used to shuffle steer when i did karting. In fact most of the time i would be making some sort of correction. I have never driven a car on the track that i felt required shuffle steering at the limits i was at (all low hp cars)..idk if that means anything but i just found it interesting.
