Instructing with a HANS
Hey Guys-
I posted my accident summary in an earlier HANS thread but will add it here. I broke my neck, C2, in a one car incident at Summit Point in 2008. I had a 5 point harness, and roll hoop in the back, no HANS and a foam collar. I think neck injuries side to side are a risk factor beyond what HANS can do. I also don't know if the foam collar aided or aggravated the seriousness of my injury, but I understand them to only offer support, and are not designed to add safety.
I went off the outside of turn 8, a slight left hand kink with a rumble strip. As I crested the strip turning slight left the passenger side continued to rotate as the rear lost grip and I started to go backwards off the left side of the track in the grass at about 60 mph. As I was sliding backwards/sideways I had turned my head to the right to see if I was going to clear the wall. I remember impacting the wall first with the front then slapping the side when my head was still turned to the right. I'm pretty sure my head rotated horizontally far enough (ear to shoulder is correct) that my helmet hit the passenger seat which, to this day, seems almost impossible when I'm strapped in, but it def hit something. I heard the crack inside my helmet (eerie) but it just sounded like my neck cracking like you might experience occasionally.
I just remember the impact was loud as **** and after I walked off the track I was having an odd feeling when I tried to swallow. That's when I sat down in a spectators car and he held my neck til the EMT got there.
I fractured both of my facets on C2 which are the rear wishbone shaped extensions that surround the spinal cord. They are not that functional in general, and sometimes are removed completely in patients with chronic disc pain and inflammation
I think HANS is designed to protect from a basilar skull fracture which is when the base of the skull that connects to C1 fractures when the skull is hyperextended forward-
HANS summary and racer deaths listed here
http://en.wikipedia.org/wiki/Basilar_skull_fracture
I had a full recovery and have some stiffness and minor pain, but only had to wear a neck brace for 3 months. Got lucky and will only go back out with a full halo seat and HANS.
Originally Posted by todinlaw; I have the Hutchens, but don't use it when I am instructing unless they have belts, same reason I don't wear my fires suit either.
LOL. I don't see the relevance either. I believe a race suit and a appropriate H&N system should always be worn when driving on track (left or right seat).
Mr. Excitement
One thought might be that fires in stock to mostly student DE cars are very rare. Fire suits are insulation, that is 100% how they work. Wearing insulation in high summer temps without advantage of a cool suit, which your student would not have, might increase the chance of heat stroke or at least cause thermal brain fade and loss of situation control far more than the chance of being in a student car fire. Drink fluids all you want, if you inhibit your internal cooling system via insulation your core temp will rise. Even a small rise can have profound results.
Does a 3 point belt setup produce the conditions that would require a H&N system? Is the added weight of the helmet alone enough to warrant H&N regardless of how well the body is restrained? From the little I have seen the body and head act very differently depending on the belt systems. I am sure this info is out there and it would be interesting to know.
Now that I'm instructing, I'm in and out of cars like crazy on track days. Often I jump out of my car with helmet and HANS on, and jump into a student's car that has a 3-point belt only. It's faster and easier to just leave the HANS on, buckle up, and go. But I'm wondering if there are any significant safety issues associated with this. I understand that the HANS won't do any good with a three-point. The question I have is if it poses any danger.
Comments?
Comments?
When I remember, I put it in my car. But many times, I forget and simply unsnapp it and leave it at the grid. Worst case, if I am pressed for time, I unsnap it when I get in the students car and wedge it, hold it, or put it behind the seat.
[edit: as a funny aside, I once saw a student [not one of mine] wearing a travel neck pillow under his helmet. Yup, the kind you use when you sleep on a plane.]
-td
Mike, FWIW, I always remove mine if I have to hop into a 3 point belt car.
Professional Racing and Driving Coach
The Penguin King
I prefer to remove the HANS when in a 3-point car. However, at the last DE I was hopping in and out of cars so much I barely had time to take off my HANS, so I found myself just wearing it. I'm trying to decide if that's much of a mistake.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
http://hansdevice.com/s.nl/it.I/id.4/.f
What type of shoulder belts work best with a HANS Device?
# Any SFI approved shoulder harness system works fine with the HANS Device.
# 2" or 3" shoulder belts in nylon or polyester work fine with the HANS Device.
# Be sure to mount and replace your belts in accordance with manufacturer guidelines. Only the HANS Device spreads the belts around your neck, preventing chafing and maximizing belt performance.
FURTHER INFORMATION
# 6 or 7 point belt systems work better than 4 or 5 point systems because they arrest the motion of the pelvis earlier in the incident, leading to lower levels of injury.
# Based upon better performance characteristics, we prefer that drivers use polyester belts.
# Remember to life your belts! Nylon loses 80% of its strength in two years due to exposure to sunlight and air alone.
IMHO, 3 point = do not wear.
FURTHER INFORMATION
I have an unusual racecar. Do you make a HANS Device that will fit?
•Yes.
•The HANS Device can be worn in virtually any vehicle (not just cars) that uses two shoulder belts as part of the driver restraint harness.
•Only the HANS Device is available in 4 angles and 5 sizes to match any application. Anecdotal reports indicate the HANS Device offers benefits even when worn under a 3-point OEM style of seatbelt. The user must also be wearing a helmet with HANS Device anchors on it.
•Yes.
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
<---Agrees with ltc that 3pt and HANS is not really going to be helpful.
Fair question. If they have a car with 3 point belts I don't want to jump in the car with a Hans device and a fire suit and freak them out. If they are to the point that they are concerned about safety and they have bought racing seats and harnesses I would wear the hans, and maybe my fire suit but i find that its a bit intimidating so I don't normally. If I am instructing someone who races, then I get the suit as safety is never enough, just don't want to overwhelm a beginner. 'Hows that"
Fair enough. After reading about Espenlaub's experience in GRM and seeing him at the track since the incident unscathed, I doubt I'll ever get in a car on-track without a fire suit again. Can't imagine how stupid I would feel sitting in a burning car knowing I left my fire suit back in the paddock.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I skipped it for a reason.
Anecdotal reports?
Glad to see H&D taking a firm stand on the topic.
For example, a bit off topic here, but I was at Roebling Road a few weeks ago, they are really up tight about you refueling your car in the paddock without a Fire extinguisher at your feet. Something my local track is not keyed into, but I got to thinking, if your going to have a fire what is the most likely time, other than a rollover, and what do you do more often. So I am going to suggest, "not require" that if people are going to refuel in the paddock they bring fire extinguisher.
Mr. Excitement
I go a form of the Gbaker route. Airbag cars with 3 point only OK, full systems on non airbag cars. No more 30 year old cars with 3 point regardless of condition. They were lacking when new.
Mr. Excitement
I slip it on my leg or soem other right there location to keep from leaving in in the car. It stays in the general area of the helmet. Don't want the chance of "nuts it is across the paddock, I will just skip it this time".
