R comps vs. Street tires
Old 02-17-2010, 11:30 PM
Brian_77_3.6
Brian_77_3.6's Avatar
I been driving DE events for about 10 years. The past 5 years I have been using Hoosiers and most recently BFG R1's. Last fall we had an event that was rainy and then would dry up and then rain again. Rather then changing wheels over and over I just kept my street tires on. They are Hankook V12 Evo's (a high performance summer Tire). I was amazed at how much grip and how little tread squirm they had. I did find braking different. Having run Toyo RA-1's in the past I found these very comparable in performance to the Toyo's. Probably only 2 or 3 seconds slower then the BFG's. I am also impressed by the Michelin PS-2's that have been on many of my students cars. There are many high performance summer tires made and they will like your street allignment.
Old 02-18-2010, 12:30 AM
RonCT
Moderator
RonCT's Avatar
Another plug for RA1s. No longer produced in my sizes (245/305 x 18), so I stocked up (1 half gone on the wheels, 2 sets in waiting). Not sure what's left in the warehouse. It's perhaps the all-around best balanced tire going. Fine in the cold and wet, great in the dry. A "real" Sport Cup (meaning not the Porsche N 19s) can be ever so slightly quicker in the dry, but you pay for it in the wet and cold.
Old 02-18-2010, 08:31 AM
Van
Van's Avatar
The PS2s are about the best street tire for the track, I've found. But they cost as much as r-compound tires.
I used to drive the MPSC on the street - no problems.
I think the RA1s and Nittos are also great recommendations.
(And I've been known to drive to Lime Rock on my BFG R1s or Hoosiers, but that's only about 40 miles for me...)
Old 02-18-2010, 01:36 PM
TAI2
TAI2's Avatar
+1 to much of the above. I like the R888's as they give you some feedback while learning, are very predictable and still provide tons of fun.
Old 02-18-2010, 01:43 PM
himself
himself's Avatar
Originally Posted by Matt Lane
Hi guys, one more classic 'dual use, good at neither' thread:
I now do about 12 track days a year, and am a signed-off (but still novice, improving) driver. I have about 30 days of PCA DE experience, spread over the last 5 years. My interest is in learning, not outright speed/performance.
I wil have a second set of wheels available and am debating whether to get R comps or good performacne street tires (RE11, Direzza Star Spec). My alignment is set conservatively (1.75 degrees neg camber) on stock ROW Euro suspension since I still do about 5K miles a year of street driving. I have been trying to maintain a reasonable wear pattern.
Are R comps even an option with such an alignment?
Alignment values aside, any ideas about the cost effectiveness of either approach (wear rate/cost of tires?)
What would you do if you were in my shoes?
Thanks for any tips and advice.
Best,
Matt
My thoughts:
First: You will get a much better return by installing your Euro seats and getting harnesses. There is no substitute for being able to feel what the car is doing. On a track under 2 miles a proper setup (seats etc) is probably worth 2-3 seconds right off the bat, and another second or two over the long haul.
Second:As for tires, they are the only thing keeping the car on the road, so you will benefit from having the right tool for the job.
Lots of people say that street tires are a great learning tool - and they are. But there are some things you don't/can't learn on street tires. Although you will learn car control skills that translate to R-comps, there is no substitute for feeling 1.5+Gs [or whatever your platform generates] under braking and in the corners, or feeling the car progressively slide at the limit. On street tires, things happen relatively slowly, so you have time to react. On R-comps, things happen quickly, so you have to be way in front of the car. There are a number of other differences, but IMO, you are doing yourself a disservice by not going to R-comps (assuming you do have a good core set of skills).
I am certain that with racing seats, harnesses, and R-comps, your progression will be much faster than with street tires and 3-point seat belts.
Third: your alignment will affect tire wear, but going from -1.75 to -2.5 degrees negative camber will not be that dramatic. A proper alignment does help, but you are not really that far off. Some tires like a little more negative camber, some a little less. But you are generally in the range to get decent performance. Keep in mind that more negative camber is good on the track, but eats the inside on the street. [I buy "hard" street tires and leave the car setup for the track].
-td
Old 02-18-2010, 03:29 PM
TheOtherEric
TheOtherEric's Avatar
Originally Posted by michel944
The fun is with R-comp tires, street tires don't even come close.
I couldn't possibly disagree more with that statement. Going back to street tires is an absolute blast. You can really push the car to its limits and you get lots of feedback to help keep from going PAST the limits and getting into trouble. Yes they're slower, but they're a lot funner.
Old 02-18-2010, 04:42 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,628 Likes on 755 Posts
Sorry OT, unless OP decides to go R compound.
How do the BFG R1's compare to Hoosiers in terms of durability?
I like how long the RA1's last and they are good to the end, but they are pricier than both the Hoosiers and BFG R1's.
18"
locally quoted.
RA1 245/40/18 $289
RA1 335/30/18 $426
Tire Rack
Hoosier 255/40/18 or 265/35/18 $297 or $300
Hoosier 345/35/18 $376
Tire Rack
BFG 245/40/18 $277 265/35/18 $254
BFG 335/30/18 $318
Old 02-18-2010, 05:40 PM
RonCT
Moderator
RonCT's Avatar
There's not as much difference between good street tires like PS2s and R-compound tires. A couple of seconds over a long track isn't earth-shattering. Telemetry (G loads, lap times, etc.) showed that there's not much difference between PS2 and the faux PSCup (19" Porsche N rated). Almost exactly the same in lateral and braking Gs. RA1s are better, haven't used Hoosiers, but I know they are gripper (but you give up wet and cold performance, durability).
Old 02-18-2010, 06:06 PM
Gary R.
Gary R.'s Avatar
Heard a rumor they were back in full production and on their site they list all sizes - http://toyotires.com/tire/pattern/proxes-ra1
I need 315/17's, have to go with NT-01's on my hot rod.
Old 02-18-2010, 06:31 PM
weneversleep
weneversleep's Avatar
May I throw a recommendation in here for the Bridgestone RE-11.
Best street tire I've ever driven on track. No, it's not an R-comp, but it's darn close. Stiff sidewalls, very grippy, minimal tread squirm, doesn't overheat unless you _really_ abuse it.
And, the "Uni-T" rubber compound construction means that the tire starts with "softer" rubber under the surface. As the tire wears and heat-cycles, that softer rubber hardens up a little bit to where it is equivalent to the grip that you started with when the tire was new.
In other words, a grippy almost-R-comp that keeps its grip no matter how much it is heat-cycled.
It truly is amazing the level of tire technology that exists today.
Old 02-18-2010, 07:46 PM
RonCT
Moderator
RonCT's Avatar
I researched what sizes RA1 were slated for return to production and got this:
The only thing we know for sure now is that the RA1's that were brought back are the ones they use for spec tires in NASA & SCCA. As fas the R888 goes Toyo has said they are going to keep it around.
We received the info back for Toyo the only 18" RA1 that will be brought back into production is the 275/35-18. No other tires at this time other than the limited RA1's and the complete line of R888's will be offered in the US.
Old 02-19-2010, 02:55 PM
Matt Lane
Matt Lane's Avatar
Originally Posted by Potomac-Greg
My vote is for you to get either Nitto NT01s or Toyo RA1s (both R-comps) for the following reasons. These tires will give you a lot more grip than street tires, and they're no more expensive then good street tires. You also do not need to worry about them "aging out" before you get full use out of them because they age well. At 12 events/year, you're doing 50 heat cycles anyway. You'd be better with more neg camber, but 1.75 is pretty close.
Personally, I moved to R-compounds a few years ago, and then last year went "purist" running a season of DE with street tires. In the end, the street tires got flat spotted and I was simply going slower and making more noise! Moral victories come few and far between when you DE in a 944 n/a, so I'm back to R-compounds this year.
Originally Posted by CWay27
I run Nitto NT-05 for street and really think they would be a great tire for you. I ran them in the constant rain at Calabogie event last september and they were great. If I were you, I wouldn't run MPSC simply because they suck in the rain, they heat cycle out before you even cord them. Really, for mild use, I would consider NT-05 or NT-01 for R-comp.
Thanks guys for the input. Sounds like RA1's or Nitto would be ideal. Appears Nitto NT-01 are not available in Canada (?). What is the best US online source that y'all are using?
My thoughts:
Good advice - the GT3 seats and Scroth 6 pt's will be in this season for sure. Looking forward to feeling 'connected'!
Yeah, it appears as much as everyon likes the RA-1's, and the fact that many sizes are still listed on their web site, they are not actually producing all those sizes. In many cases, there is some remaining stock to liquidate, but that's about it. I'll give the NT-01's a shot and let you know how it goes.
Best,
Matt
Old 02-19-2010, 03:01 PM
Matt Lane
Matt Lane's Avatar
Quick follow-on question:
The appeal of the RA-1's was their wet performance. I understand that PSC's are specifically bad in the wet.
How do the NT-01's fare in that department?
Best,
Matt
Old 02-19-2010, 03:15 PM
Matt Lane
Matt Lane's Avatar
Please disregard my question re. where to buy Nitto's online. I found the recent thread on the subject.
M
Old 02-19-2010, 03:46 PM
himself
himself's Avatar
Best,
Matt
The appeal of RA-1 is not the wet performance. It is the longevity for performance. The tires run great right up until they cord. However, RA-1s really needed to be shaved, so the wet issue becomes moot. Same goes for when the tread wears down. The NT-01 is also a good grip tire with long life - but it typically runs better at full tread than the RA-1s did.
The MPSC is not a great tire IMO for short sessions. They take too long to get operating temperature.
-td
Quick Reply: R comps vs. Street tires
