6-Point Harness Belt Help Needed....
I met up with a prior owner of the 993 Turbo I bought from d-land and got a Brey-Krause Harness Mount Bar R-1010 and 6-point Deist harness belts from him.
I got the harness bar installed without issue. The belts are something different.
I figured out the lap and harness belts. However, I can’t figure out the anti submarine belts. The anti submarine belts also have the buckle that the harness belts and lap belts fit into so they have to be used. Don’t they?
Thanks…..
![](http://www.bkauto.com/porsche/images/R-1010.jpg)
![](http://img.photobucket.com/albums/v216/cwampler/P1090762.jpg)
![](http://img.photobucket.com/albums/v216/cwampler/P1090763.jpg)
Thanks…..
![](http://img.photobucket.com/albums/v216/cwampler/P1090761.jpg)
Basic Site Sponsor
Basic Site Sponsor
Yes, it is integral to the system. You need 2 clips to fasten the sub belt to eye bolts securely mounted below the seat. Route it up through the hole in your racing seat. BTW what you have there is actually 6 point harnesses as they mount to 6 places.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Thanks Larry, I changed the posting to read 6 instead of 5. I have the OEM sports seat, so no hole in seat. When you say to mount below the seat, what am I attaching to? Do I fasten to the pan by drilling a hole in it and attach an I-bolt or do I attach to the seat bolts?
u need a seat that's built with a crotch hole.
typically u attach to eye bolt or some frame structure. fastening to the floor pan...i believe it's legal but not necessarily safe.
i thought i remembered there was a 911 seat bracket that had a cross beam for the subbelt...
Basic Site Sponsor
Basic Site Sponsor
I am our region's Technical chair and also help with safety inspections. If you don't have an experienced racer or long term DE driver to advise you, PM me with your phone number and I will get you pointed in the right direction.
Another point that should be mentioned that I haven't seen anyone point out yet:
That harness bar looks to be intended to be a harness GUIDE bar - that means that the belts are run over the bar (or rather through the holes in the bar) for proper positioning, but the ends of the belts should NOT be anchored to it. You'll need to anchor the belts to a strong point in the rear seat area (a roll cage, or rear seat belt anchors).
Mr. Excitement
Please listen to Larry H even if you don't plan to track the car. He typeth good gospel. I was a Tech Chair as well and the setup you discribe will not pass for PCA track events.
Yes, that looks like a guide bar and the belts you have in hand look to be too short. If it is a guide bar it is not intended to have the belts mounted to it only over it and down to the back seat belt points.
As it is you have a bar that does not work with the belts and a seat that does not work with the belts. You need to change the seat and the belts or the seat and the bar to the B/K Truss or to a bolt in roll bar.
Also, since it sounds like you are new to DE's - most PCA (if not all) events require EQUAL restraints for both the driver and passenger. Installing 6 point harnesses will mean you need proper seats and harnesses for both sides. Those Deist belts look like my original 2005 belts, what is the date on them as they may be expired (meaning you won't be allowed to run some places)..
Thanks to everyone for their replies. I'll take a closer look at them tonight. At this time I only plan on auto crossing. DE is an option in the future. This may not be worth pursuing.
You are safer using your stock seatbelts versus incorrectly installing harnesses.
A quick fix for autocross is a CG Lock. It locks the lapbelt in place and keeps your butt planted in the seat. Approved by SCCA for autocross.
We have one left in stock (currently on backorder with CG lock) if interested.
http://www.apexperformance.net/CartGenie/prod-912.htm
I've had folks at the track doing laps with their stock belt and installed a CG lock. Said it helped immensely where they didn't have to use their legs to brace themselves in the seat through the corners.
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
Last edited by ApexPerformance; 01-29-2010 at 10:34 AM. Reason: add link for cg lock
Concur with everything said above. That said, can you believe what we used to let people out there with in the '80's and '90's? Safety has come a LONG WAY in a short amount of time.
Many thanks again for all of the advice. Based on the information in this thread, and some additional searching on Rennlist, I will not be using this set up. The belts are too old; I have the wrong seats plus a few other issues. This was my first posting on the Rennlist Performance & Competition Discussion Areas, Racing & Drivers Education Forum. Thanks for the advice to newbie to this section.
