Is it really necessary to use the clutch when downshifting?.....
Old 01-24-2010, 12:17 PM
Mark Dreyer
Mark Dreyer's Avatar
When Ron Zitza coached me a few weeks ago, he laughed when I asked that same question. He is a proponent of double clutching. He drove my Boxster and I couldn't tell his double clutch apart from a normal heel/toe. He is very smooth and that Boxster has never gotten around Sebring so fast ever before! It was cool seeing cars with much higher HP giving him the point by, something I've yet to experience.
Old 01-24-2010, 01:44 PM
93 FireHawk 968
93 FireHawk 968's Avatar
Why????
Old 01-24-2010, 02:05 PM
Mark Dreyer
Can't remember his exact rationale although I think it has to do with his opinion that you can be smoother with double clutching than with heel/toe.
Old 01-24-2010, 02:43 PM
dan212
dan212's Avatar
I don't think double clutching precludes heel/toe.
Double-Clutch is a habit from 30 years ago. After a while, the older synchro's were toasted and you HAD to. Modern gear boxes don't require it as much. If you pay for your own maintenance, it isn't a bad thing to do. Try going from 2->1 with any speed WITHOUT double-clutching.
So I do it when I can - which isn't often on the track.
Old 01-24-2010, 02:54 PM
Gary R.
Gary R.'s Avatar
Am I missing something? If you are double-clutching you aren't braking, if you are heel-toeing you are. though you can double clutch AND H/T at the same time..
Old 01-24-2010, 03:05 PM
KS-CS
KS-CS's Avatar
Double clutch down-shifting (+/- heel-toe blip) is usually done under braking isn't it?
As dan212 pointed out, I found it a useful skill to practice for going from 2nd to 1st on AX courses.
Old 01-26-2010, 06:44 PM
BostonDMD
BostonDMD's Avatar
Thanks for the inputs.....
I have decided that I will try the clutchless downshift myself with full video and sound on......
Just as soon as someone offers me their race car to try it in.......
Old 01-26-2010, 07:25 PM
Gary R.
Gary R.'s Avatar
$35K and you can use mine!
Old 01-26-2010, 08:16 PM
BostonDMD
BostonDMD's Avatar
Nobody talented enough to buy you podium race car yet?
Old 01-26-2010, 08:29 PM
Gary R.
Gary R.'s Avatar
Not many out there as crazy as us....
Old 01-26-2010, 08:36 PM
BrandonH
BrandonH's Avatar
only reason for a clutch in a formula ford with a hewland is getting rolling from a standing stop. (ok and I guess to prevent stalling engine while spinning)
Otherwise it slides in and out of gear like a rifle bolt, and sounds like a paddle shifter at speed...
Quick Reply: Is it really necessary to use the clutch when downshifting?.....
