Pictures of PCA Stock Class Interior
NASA Racer
ah, i get what you mean. i can't imagine a scrut would move you to prepared for trim which is a definite gray area. my cage meant deleting most if not all the trim. the scruts have been really good about not punishing for things like trim which are meaningless in the grand scheme of things. you can remove the headliner, anything that interferes with the cage and Donna issued clarification to a Rennlister that anything that is part of an RS carpet kit in a 911 can be removed. i think you can keep it pretty darn clean.
Ben, David, Gary, et al...it was a ton of work, which I did last winter in preparation for installation of the custom welded cage. It would be nearly impossible to do now with all the bars in the way. The car is a non-sunroof Euro SC, and with everything removed, it weighs under 2400 even with the cage and nitrous bottle. ![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
There are several different adhesive removers you can use to take the carpet glue off, such as Goof Off, Goo Gone, and 3M Adhesive Remover. All are pretty toxic, and will give you a headache after a while. The stuff I used came in a can, but I put the sprayer part of a windex-type bottle into the can and sprayed the areas first, letting the agent soak in before I wiped it away. You just have to scrub and scrub to get it all out. In some of the dry areas I used a metal brush on the end of my drill.
I painted it with a brush and layed it on really thick. Here's what it looked like after the carpet came out, but before the glue was removed.
Do not take the toxic warning lightly. Be sure to wear a high quality respirator( the one with the replaceable filters). I took on a project like this several years ago when I converted the interior on my 993. I did it over a 3 to 4 week period in a poorly ventilated garage. It was winter and I chose to leave the garage doors closed in order to stay warm and did not wear a respirator. I started getting bad headaches towards the end of the project. A week or so after completion I started getting massive headaches, dizzy spells and vomiting. I had to be rushed to the hospital for an MRI. They thought I had a brain tumor! They eventually treated me for vertigo, but my wife believes I poisoned myself. I had to go on a detox diet for a month! Take extra precaution and make sure you take breaks and walk outside to get fresh air. A lot of it is common sense, which apparently I don't have.
I think I want to do tackle this project on my 911.....
Is it complicated or just time consuming?
I mean, all I would need to do is remove the seats, rip off the carpeting, remove the glue,
freshen up the paint and place the seats back on, right?
Chris M: congrats! Looks great. Wish mine looked half as good!
I am in the process of removing RS carpet from floors and headliner.
Headliner and carpet on passing side are out and most of the glue removed. What a bitch of a job. Slowly working my way through the roof.
I plan to paint the floors black by brush and spray the roof with automotive paint to match the exterior.
I tried many different solvents and glue removers. Methyl Ethyl Keytone (MEK) works the best. Pre-wetting helps alot. Floor surfaces are MUCH easier than the roof (I have to work around the cage).
Never work w/o carbon filter respirator that fits smug.
I plan to finish the roof and floors before I start the back area.
I'll post pix later.
Here is the current state of my car. The bolt-in cage is removed and the dash is almost out. I need to gut the doors for NASCAR bars. Fortunately, most of the bad stuff was removed when the bolt-in went in several reays ago. It looks like a new paint job is in order.
For those of you that plan to tackle this project over the winter.
Here's some info on MEK: http://www.ccohs.ca/oshanswers/chemi...ealth_mek.html
That's not good. Do you have the garage doors open? These chemicals affect people differently. It's not worth the side effects. Have someone else do it. Trust me on this one.
I just stripped my interior this weekend. Took about 10-15 hours and I still need to paint it. I still had my cage in which made it fun since my chest is now bruised from leaning on the door bars all day long. What I found to work best is to use a 1" stiff scraper and a heat gun to get the thick tar off. I then used a 4.5" angle grinder with a Dewalt wire cup (opt for the wound wire one vs crimped) and some citrus based tar remover that I got at Autozone. Took all the tar glue and left over padding off. Finally I went over it with a paint remover wheel on the grinder and I now have a nicly stripped interior which is about ready for paint. It was a PITA but it looks good and should turn out well. Im hoping to also keep out some of the trim pieces as in the 944 the only ones to go back in are next to the rear seats and one could argue that it gets in the way of safety. I mean for the 5 pds it adds I may throw it in just to be safe or at least keep it in the trailer. Im hoping to get the final cleaning of the interior tomorrow and will post pics then.
