JIC vs Moton Clubsport vs Moton 3-way
It's that time of year again (upgrade time) and I'm considering upgrading my JIC Cross suspension to Motons on my Boxster S.
Assuming everything else stays constant, how much laptime improvement should one expect going from JIC's to Moton Clubsports? How much more would be gained going to Moton 3-way motorsports?
Has anybody actually done this upgrade and have real experience to back up the numbers?
(Oh, and I have already done a search, but I haven't found any really useful info other than "Motons are better than JIC". I'd like to get an idea of how much better so that I know how many $$$ per second I may be spending)
Basic Sponsor
My best guess is .01 seconds per $ spent.....
WAY WORTH IT..
WAY WORTH IT..
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
I think it will depend on the track layout and even moreso, the surface. The JIC are terrible on anything with curbs to jump or lots of bumps. At least mine were. I've heard the Clubsport is much better from those that have switched. The 3-ways are a whole cut above the CS. However I really like the JIC on smooth surfaces, but had to run full stiff because the springs rates were way too soft and even then the car rolled.
But I'm halfway in your shoes now, have problems justifying 8k all in on Clubsports when you can just go for it and get the 3-ways.
You can set the JIC's up for different spring rates. I just sent mine back to Jon for service. After thinking about it for some time, I decided not to change my spring rates from the 700/900 set up I have now although he told me he could.
I like the JIC's but to be honest have not driven a car with Motons hard enough to see a difference.
Brian,
I went with Moton CS's with improved spring rates over JIC's's based on feedback I received from others who claimed the Moton upgrade was superior to the JIC's. I do not know how the JIC's would have performed but I do know I picked up close to 2 seconds at NJMSP Lightening and 3 seconds at Thunderbolt. Similar improvement was observed at WG, Lime Rock and Sebring. Now a portion of the decreased lap times is associated with better driving and knowing the tracks better but the turn in and overall handling was improved significantly.
I agree with others about how well the Moton's improve handling over rough surfaces, the stability is outstanding.
My suspension improvement have been in phases;
Koni's with rubber all around.
Removed the rubber and went with solid bushings front and and back.
Installed power steering.
Added Motons.
Added 18's.
Now I have no excuses...
Added Motons.
Added 18's.
I found about a second when I changed from JICs to 3-way KW motorsport (which are equivalent to the Moton 3-way motorsport shocks). It takes a lot more time and effort to get the 3-way set-up with the right springs and bump/rebound settings than the extremely simple JIC. Don't expect to slap on the new suspension and go faster - it took me all year to get them close to dialed in to gain that second.
Brian, as I posted in another thread, starting in January, the Club Sports will be identical to the 2 way Motorsport models. They are awesome on curbs, berms, aprons, and bumps, as well as rough tracks like Summit Point. Do you need 3 ways? I seriously doubt it...
Professional Racing and Driving Coach
I went from stock 993 suspension to JICs (8/11 kg/mm = 450/620 lbs/in) two years ago. During that first season, the simplicity of one adjustment **** made experimentation very easy and helped me learn how the basic adjustments changed the car's handling. The set-up is very good and I was able to adjust for smooth tracks (WGI and NJMP) as well as bumpy tracks like Summit Point. For the money, it's a tremendous set-up (including very high quality camber plates/rear upper mounts).
This past season, I started experimenting with different alignment settings and analyzing data. By the end of the season, I think I had the car set up very nicely and she performed pretty respectably at my first PCA club race at NJMP.
However, I love the tinkering and engineering part of motorsports. For me it's all about learning and getting the most out of my car and my own performance. The next logical step in the learning process was more adjustability and perhaps stiffer springs, so I installed JRZs last weekend with somewhat modestly stiffer springs.
I'm hoping that the baby-step approach will make the learning and transition easier. I'm expecting a lot of experimentation (and perhaps professional assistance) to get the car up-to-speed again (and then it will be time for the next major overhaul).
Hi Glen, let me know if you get some professional assistance this year on setup, as I'm interested in that too. I'm in the process of swapping out the JIC setup for a Moton triple setup.
I have JIC's on my 993 C4S with very heavy springs - 10k/14k. I think they are a much better option then a PSS-10 setup, but I wouldn't put them into the Moton / JRZ category.
Also, I have seen a lot more JRZ setup's recently than Moton. I don't know if JRZ is more aggressive or providing better support.
