Advice on instructor seat/harnesses for my DE car
I've been converting my 1986 951 into a DE/Track car. At this point, I've stripped the interior and installed a rollbar (which is designed to become a full cage at some point in the future). I've got a Recaro profi SPG seat. I will be getting harnesses and a head-and-neck system.
What should I do about a seat and harnesses for the instructor?
Would it be bad form to find an expired FIA seat? used harnesses?
If I'll be getting 2" shoulder belts to accommodate a HANS for myself, should I get 2" or 3" for the instructor?
I'm looking to do this as cost effectively as possible since the eventual plan will be to remove the seat and harness for the instructor.
Thanks for your advice!
The Penguin King
I'd recommend a 3" belt for the instructor side since many/most of them don't wear a HANS to instruct. If they have a HANS, the 3" will work. If they don't, 3" is better for them. jmho
not sure if this is a national pca requirement; but you would need to put in "like for like".
if the driver has 5/6 points, then the passenger has the same type.
not necessarily identical, but the same type.
btw----5/6 points can only be used with a seat that has the shoulder holes.
Buy and install the most expensive, best quality products available for the instructor. These people are putting their lives in your hands to help you be a better driver. They deserve the best.
(yes I instruct)
(yes I instruct)
Put your good seat for the instructor, buy a cheap seat for yourself... then when you don’t need an instructor anymore, swap them.
But assuming you will keep doing DE, at some point you will probably instruct and need a good seat to take students in. Buy 2 good seat and harnesses... This is not the place to try to save money, for yourself or anyone else.
Just my 2 cents
Just my 2 cents
Still plays with cars.
Most PCA regions and all of zone one call for equal restraints for driver and passenger. Would you ride with an instructor who had a lawn chair on the passenger side?
The Penguin King
Guys, lets give the OP the benefit of the doubt.
I agree that attention to equal safety needs to be paid. However, that doesn't have to mean equal cost. For example, you might put a lighter weight seat on the driver's side. Or maybe a halo on the driver, but a non-halo, low bolster on the passenger side. Or a Recaro on the driver's side because it fits you better, but a Sparco on the passenger side. Safety and $ are not always directly proportional imho.
Good advice and good idea. If I get in your car and the passenger gear is obviously not as good as the driver gear, then you'll need a new instructor.
I'm in....
If you are going to run with PCA then an expired seat will not cut it unless you put in a seat back brace. I can see why fiberglass seats may have a lifespan but I'm not sure why it also applies to aluminum seats.
You could just skimp on both like I am going to. Half kidding. I will be doing HPDE's with NASA until I can get my license so I don't need to worry about all this PCA stuff and full on racing just yet. I will be getting 2 Corbeau reclining seats for the next season. They are cheap and comfortable. That way I get the benefit of a seat that holds me in place and I can drive to and from the track. You probably won't be doing any full racing right away so this might be an option until you are done with an instructor. They probably don't add much safety, but while I am learning I won't be going to the limit. Once I am done with an instructor I will remove both of those seats and install one dedicated, approved racing seat on the drivers side. That would be your Recaro in your case. If I get to that point then the whole car will be stripped down and it will not be driven anywhere but the track.
