iphone lap timers
#32
I suggested an update too. It doesn't seem like they're much on customer service.
#33
for those using the google android phone, another option that i found to be very reliable and extremely accurate (esp for the price!) is this little app: http://trackmaster.trackaroo.com/web/trackmaster
i was skeptical but after trying it at the local tracks, it works flawlessly! great product, no affiliation, blah blah blah...
#34
Harry's Lap timer seemed to work ok today at NHMS. I got lap times for all of my laps in each session. I can view maps that show speeds on the straights and in the corners. I haven't been able to export the data yet - can't figure out where you are supposed to enter your email address (I keep getting an error saying the email address is not valid but I haven't entered one yet). For me, automated lap times is worth the $4.99, everything else is just a bonus.
#35
Did you mount the iPhone on your dash or have it in your pocket?
dave
#36
Dave,
I "mounted" it to the dash with two small pieces of velcro. I have a phone case that I never use so now it is my track case.
I tried to mount in on the transmission tunnel behind the shifter but the GPS receptions was not good enough to work. With it on the dash I just have to remember to hit start before I tighten my belts all the way.
Kevin
Kevin
#37
Dave,
Kevin
Kevin
#38
With Harrys app, i set the POI as a start/stop while i was standing right at the edge of the track at the start finish line but it recorded my entire 30min session as one lap.
Then i tried setting another POI as an intermediate as well but same deal, recorded entire session, no trigger events.
I have the iphone 3GS mounted on the passenger side front footwell with velcro and was getting 1Hz signal. Its a good spot because you can plug the phone in at the 12volt outlet in the footwell.
So do you think I needed to wait longer for the iphone to get the fix on my POI location when i set it?
How does the timer know which POI to use?
#39
Have you been able to export data? I can't figure out where to enter myemail address.
Kevin
#40
I emailed Harald and he got right back to me.
It seems that the default parameter for the POI detection is narrow and it should be wide, he is going to revise this. You can find this in the general settings menu for your iphone down at the bottom of the page. Look for POI detection under the GPS heading.
You also enter your email info there as well.
#41
#42
Kevin
#43
Some updates... (cross-post)
Log Box released version 1.2, which fixes the problems I ran into earlier and works pretty good. It's a minimal app for a low cost, but you can now easily use it as the basis for video overlays with RaceRender 1.4.1 or newer: http://www.youtube.com/watch?v=NjtoJiQ4-xg Log Box is now the best and lowest cost iPhone app that I know of for exporting GPS and accelerometer data, and that's all it really does.
Harry's GPS Lap Timer had some updates as well, and can now export entire sessions, sort of... The problem is that the sample rate and timestamps leave something to be desired, so it's still not great to use for exporting data. But aside from that limitation, it's a really nice app that does quite a lot within the iPhone app itself. If you don't care about exporting data to your computer for making video overlays or doing further analysis, then it may be the only app you need.
With any app, you'll need to work to find a good GPS reception spot inside a car. The best I've seen is 9 meters, but it typically fluxuates between 9 and 17 meters. If you don't try at all, you'll probably end up with something like 47-76 meter accuracy, which is what I had in the video I linked. The accuracy problem is more apparent when doing laps around the same course.
#44
Did you use only an iphone and no additional GPS device?
Craig
