Tow vehicle milage
#46
I guess I'll chime in...
'06 F-350 SD CC 4x4 w/ 24' Millenium enclosed trailer
19,800# with all my gear
I get 11 to 12 MPG running 65 or so and am happy w/ that
I've gotten up to 19.3 MPG highway running light
#47
I have a 2001 F150, 5.4 2WD. I get about 15.5 on the highway empty and about 10-11 pulling a 1500 LB steel trailer with a tire rack, and a 2950 lb car at 70 MPH.
F150, Triton5.4, 4wd. Get 12.5mpg on a good day without the trailer. With closed trailex and lots of spares, I get exactly 10 going to the glen or SP. Maybe 11 without hills. Usually keep it to 70 mph or so.
Mileage sucks, but the trailer hardly makes any difference. The pickup is actually taller than the trailer.
#50
I pay very close attention to tire pressures, but only on my car. Time to check out the tow vehicle tire pressures this weekend.
#51
Originally Posted by NJ-GT
So the consensus here is that everybody is speeding, and the 16 mpg Diesel rating with an open loaded trailer is a fairy tale.
I use to be a frequent poster on the old Ford Diesel forum, the mileage claims were always realistic...that is if you live in a Plains state, keep it between 50-55mph and only drive with helpful to at worst nuetral winds.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Dodge guys use to claim 20's for mpg with the old 5.9 engine...sheesh!
#52
Query: how does your setup handle the decent into Montour Falls when leaving Watkins Glen?
-Z-man.
#53
Z-Man I like to live on the edge!! actually the car is closer to 2100lbs and the trailer has surge brakes so no problem on the emergency stops or hills etc.. I keep the car back on the trailer to keep the tongue wgt to a minimum. Even with spares and tools etc, I figure I'm still within the limits. I was 60-70all the way home on rt-17. On the way out to WGI, a caravan of dually diesels towing boxes blew by me at about 80-90mph!! Save the racing for the track boys!!
#54
FWIW - payload on the Sienna is 1570lbs and I typically don't carry those wheels and tires, I was just carrying up for a friend that particular time.
"heck - even my Sport Trac (rated at 7,000lbs towing) is barely enough..."
I'm surprised about that. I'm cruising with the a/c on and almost don't know it's there except for steeper hills... Time for a Tundra....
#55
2008 Mercedes ML320CDI. Rated at 7200 lbs towing. Diesel with air suspension, towing kit which includes modified ECU to respond to trailer problems. Tow a GT3 on a Trailex open trailer with tire rack. My experience
1. Towing trailer with tires at 65 - 70 MPH: 15 - 16 MPG
2. Towing trailer without tires at 65-70 MPH: 16 - 17 MPG
3. Highway driving at 65 MPH without trailer: 27 MPG (really)
4. Highway driving at 55 MPH without trailer: 29 MPG
#56
My concern is that on paper, my numbers are a little on the low side of things.
Though I've had a few "need to stop in a real hurry" moments, I've never had to execute an emergency maneuver while towing. That's when the 'bigger is better' mantra of tow vehicles somes into play.
I chose my Sport Trac because it does double duty - tow vehicle and daily driver. I wanted a two vehicle with sufficient buffer in terms of capacity, yet still be comfortable as a daily driver. I suspect your choice of the Toyota minivan is also because of such compromises.
-Zoltan.
#57
butzip - I have never had problems when towing with my Sport Trac - uphill, downhill, crosswinds, A/C, rain, hail, tornado (yep - drove through some severe weather going out to Mid-Ohio a couple years ago)...etc.
-Zoltan.
-Zoltan.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#58
