Towing Issue
Old 06-29-2009 | 06:48 PM
CCA's Avatar
CCA
Default Towing Issue
For some reason when I'm towing my car, my truck feels like it has a wheel out of balance. I had the tires re-balanced and the truck aligned, because the tires were showing some signs of cupping. However, I'm not real convinced my Toyota dealer actually did an alignment, because the rusted-up alignment bolts didn't look like they had been touched. With the torque they they need to break lose & set, they should have had some wrench marking on them. And, yes I did address this with them. Anyway, the tires have also been rotated and the truck still has this shake going on. The trailer tires have not been balanced, a tire shop I spoke with said it wasn't necessary, but I gotta do something about this. I'll be towing 7-hrs up to Watkins Glen at the end of the month and I don't think I can deal with it for that long. So is this a truck alignment issue, trailer tire balance issue or a trailer load issue? Any thoughts or suggestions?
Old 06-29-2009 | 07:20 PM
Juan Lopez's Avatar
Juan Lopez
Apart from checking the obvious in your truck (alignment and tire balance) check your tongue weight. Could be that its too high and the resulting lower weight over the front axle (or change in the angle of your tow vehicle) is "changing" your alignment.
Old 06-29-2009 | 07:30 PM
jscott82's Avatar
jscott82
+1 on tongue weight... But I would also get the trailer checked out, bearings, brakes, lugs...
Old 06-29-2009 | 09:46 PM
LDadrenaline's Avatar
LDadrenaline
+2 on tongue weight. make sure your trailer is not only properly balanced in terms of weight, but also that it is riding flat when it is completely lowered on the truck. I see people with major height differences between front and rear all the time.
Old 06-29-2009 | 09:49 PM
MUSSBERGER's Avatar
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Balanced trailer tires do make a difference. But I don't know if this is the answer.
Old 06-29-2009 | 09:58 PM
lawjdc's Avatar
lawjdc
What year and model is your Toyota truck? Does it have the TRD Off-Road suspension?
Old 06-29-2009 | 10:12 PM
CCA's Avatar
CCA
It's a '00 4x4 with the TRD package.
Old 06-30-2009 | 12:25 AM
lawjdc's Avatar
lawjdc
I have a '06 tundra with the TRD package. The open Featherlite trailer I have acts like it has wheels out of balance. It doesn't, and the axles are also perfectly true. We finally traced the problem to the TRD suspension on the truck. Its just not ideal for towing and tends to "hop" slightly at certain speeds. I haven't done a fix yet, but I suspect that may be your problem also.
Old 06-30-2009 | 01:00 AM
Darren's Avatar
Darren
Tire rotation is also important to keep the tires from cupping like that. That will definitely feel like a wheel out of balance.
Old 06-30-2009 | 01:07 AM
A930Rocket's Avatar
A930Rocket
Could the tires themselves be out of round? I have a set of Khumos that have driven me crazy. Had them balanced and rotated twice, replaced the rotors, then had the drive shaft balanced. Took the truck to Gran Turismo while I was in Atlanta and the mgr said it was the tires. You could see them going up and down slightly. No balancing will fix that.
Old 06-30-2009 | 11:37 AM
CCA's Avatar
CCA
Hopping is sometimes the feeling I got from the steering wheel. I have a 2200# full deck steel trailer and the car rolls in a little under that. Maybe I'll get on the Tundra forum and see what alignment numbers I can come up with.
Old 06-30-2009 | 11:50 AM
CCA's Avatar
CCA
Yeah, I get some noise and maybe a little vibration from the tires because of the cupping, but the shaking I believe is either coming from the alignment or a trailer issue. In a few more Ks I'll have the Tundra's tires flipped on the wheels and try to balance out the wear.
Old 06-30-2009 | 11:53 AM
CCA's Avatar
CCA
I don't think so on the truck, but that could be a possibility on the trailer.
Darren's Avatar
Darren
Once they cup they are toast -- it's like doing burnouts trying to get rid of flat spots on track tires -- doesn't work. I've replaced several tires for this reason on my truck. Usually the front ones cup and you can lessen the effect by putting them on the rear.
Old 06-30-2009 | 02:57 PM
RedlineMan's Avatar
RedlineMan
Hmmm...
Apart from weight balance/tongue weight issues, I'd have to say the main problem is that it is not an ideal tow vehicle. Might not make you happy, but that is the truth. The only way to make these little trucks work is to use some fairly heavy distributor bars. Even then, they are marginal at best.
Quick Reply: Towing Issue
