Help! Cracked Brake Pads?
Run those chick-lets, Those are fine. Try not to go to full metallic thats a little tough on the rotters.6-5mm toss em. I never had as much luck with pagid ( I ran the orange).I prefer PF's and hawks.
Regards
TSheehan
Regards
TSheehan
The Hawks I've used (HP+, HT10) have cracked/chunked but not to the point that they weren't usable....never a problem with PF97s.
GT3 player par excellence
you probably were very hard on the brakes and didn't give them enough cool down time before you parked it. however, they are still good and i would just keep using them. some ppl throw them away at 5mm, but i run my right to the backing.
^ if you worry about your brake pad, wait 'til you see mine. you probably faint and freak out.
sometimes i use the backing plate as the pad. that's usually when i set my best laps, less brakes.
you should come out to a DE event with PCA GGR. the next one is 8/1
And yes, I will be out with GGR at THill :-)
^ see you there. not sure which car i will be in but they are always number 868.
