MichelinPS Cups, Toyo R888's, or Yokohama Advan A048's
#61
Ok, I finally get how to communicate with you.
Yes, you are right VR. You are always right, WE ALL are always right.
There are a million truths out there.
My truth is R888s are made from the same compound as the RA1 and I like the RA1 and there is some resemblence to them
Your truth is that the R888s are different than the RA1.
we both speak the truth.
Now, go get that driving suit washed up for August!
mk
edit: One thing we do disagree on is how the 30+ heat cycled tires have SO much less pick-up than the 5 heat cycled, same size, same car,same day, (near ) same time, RA1s, IF, the were not as sticky as the newer one. Dont believe EVERYTHING you hear. Its not all white or black here VR. RA1s fall off LESS than other brands of tires with heat, time and heat cycles, but still fall off.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
mk
Mark, again, the 888 is a very different tire in almost every way, so comparisons with the RA1 are facile at best.
And your second paragraph is pure projection intermixed with a supersize portion of irony. Sorry that everyone here but you sees it.![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Professional Racing and Driving Coach
