Anyone tried a 255/35/18 on the front of a 968?
"Jason, I believe you've come down in size (at least on the rears). What are you running all round and would you say there's a noticeable difference to your previous set?"
_______________________
Patrick,
Yes, I've come down from 315/30/18 to 295/30/18 R6's in the rear...While I was doing DE's it seemed the 315's were fine. But, when I started to race, and drive the car harder, the 315's were rubbing. I got black-flagged at Limerock during practice sessions, but they let me back out afterwards.
I've been told the 295's shouldn't react much differently...and I'm keeping the 275's up front.
I'll be trying out this combination at the Glen this coming weekend. We'll see what happens...if anything.
My guess is that I won't feel a difference.
Patrick,
"What tendencies do you have re under / oversteer in your car now? What sort of spring rates are you running too? "
_________________
The car is pretty neutral, actually...I've recently had Motons installed, and now we're running softer spring settings than before...something like 550 all around, and softened up the Motons a few clicks, too. I find the car to be much more compliant and manageable; even though it's a bit softer...Go figure!
Reminds me of that saying attributed to some NASCAR suspension tuner..."Looser is faster" or something like that.
_________________
_________________
_________________
Softer will usually give more tyre grip but of course allow more body roll / pitch. It's always a compromise.
I saw a guy at the track the other day with 3 -way Motons. Cost over $8k US!! Very nice....and they'd want to be.
I'm running 900 and 750 pound springs with Moton 2 ways. Torsion bars were machined down to 10 mm. Great set up, though I am following the tire discussion with interest. Thinking of moving from 245/45/17 & 275/40/17 up to the 18's for shorter gearing.
For anyone interested, I have 2 lightly used Toyo R888s in 255/35/18 off the front of my 997. They were not shaved and have only 12, 25 minute DE heat cycles on them. They are very evenly worn and have a solid 3 to 4 MM of tread on them. I switched to a taller setup (245/40) for various reasons. The tires are structurally sound. I will let them go for $300 shipped for both. PM me if interested.
For shorter gearing you should look to using the S2 ring and pinion. I've had it in my car for some time and it's well worth it. Shortens your final drive by about 15%. Depending on your tracks of course, but I would imagine I could hit about 150mph still. Need to do the calculations.
I feel you will need to soften (I decreased bump) to use wider fronts. I think the 968 has less understeer with the 255's vs 245's. Some of the guys are using 285's all the way around.
Mike
Mike
