How PCA racing needs to reorganize
The difficulity with a spec tire for stock classes is mostly the issues of sizes. There is not one MFG that makes all the sizes needed for cars in stock. There is wide range and really Hoosier is one the makes the most. Spec hoosier is not going to help budgets.
Now a spec tire in class where their are few size is great. Sadly I can't see how it will work in all of stock.
Most of the cars in stock classes are in D to H and most of those leading the packs are all on 245/40/18 and 285/30/18 (or something very close). It is not necessary to have all sizes so long as a suitable size for each car is available. After all, everyone will be choosing from the same available sizes. I would be more than willing to make small changes in size if I the tire would get 3X the number of competitive heat cycles.
So this brings us to the crux of the matter, the stock and prepared classes. Since I have whittled away 10 classes, we should now have enough room to have separate stock and prepared groupings. Stock can really be stock now, with rules designed to allow for cheap but effective modifications like camber plates (cheap & saves tires) and non-adjustable shocks. Expensive ones like remote reservoir shocks should not. Brakes should be stock, but any wheel that fits under a stock contour fender (rolled lips are ok) should be allowed as long as it is a single piece wheel. Interiors can be removed, but dashboards and passengers seats retained for the stock look and DE purposes. The current motor rules are good, but since many chip their motors for DEs, and it is allowed everywhere else, let it be legal. Motors & transes should be stock.
Prepared should bring the cars up to a new level, but with significantly less cost than a modified version of the car. Motor internals, cams, pistons, intake & injection etc should be stock except for specific reliabilty changes such as better retainers, stiffer valve springs and the M96 longeveity mods that are beginning to surface. Transes, brakes, and suspension parts should be free along with a 150 lb weigh reduction across the board. Bodywork can be free (but with a handicap formula for cars with flared fenders). This will allow those who run in NASA to more easily re-ballast their cars so they can come back and compete with us.
Hopefully, a better thought out 3 tier level to our program will allow for more cars to be competitive in their classes, and enable those DE specials and other racing series cars to come into PCA..
1) No adjustable shocks in stock? That rules out even relatively simple shocks like PSS9's. Maybe, you meant no remote reservoir shocks in stock?
2) Let's allow removal of the passenger seat. Personally, I hate the rule that requires it simply because even if we go back to the idea of PCA being the place to race a street legal car, to the best of my knowledge, passenger seats aren't required in street cars.
3) Single piece wheels only? Is there that big of a difference between CCW and BBS that we need to make it a stock only rule?
4) Stock motors for stock... This is where the trouble is going to come in. As many know, there is a "stock" motor and then there is the really stock motor. This is where NASA's HP/weight classification system seems to work well.
To keep costs down in the stock classes I think some consideration should be given to going to a spec tire that can handle a higher number of heat cycles without falling off. I would personally be in favor of it. Sure its fun to smoke the hoosier crack pipe, and I continue to do so, but I could run more races if I could reduce tire cost.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
What's considered a "high number of heat cycles?" I put DrJupeman on my 22 heat cycled hoosiers for the enduro warmup/practice session at Watkins Glen and he was able to bust out a 2:11.9.
Methinks that some people are throwing out their Hoosiers before they are truly used up.
Basic Sponsor
For what its worth, carpet in any race car is a really bad idea. Mandated nomex suits and fire proof seat material to be put on top of flamable carpet...WHO is doing the thinking over there..???
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
No. I have 2 sets. One for racing, and one for practice. After the practice ones are totally used up, the racing ones become the practice set, and then I get a new set.
If something were wrong with the racing wheels, then yes, we would have used the practice set for racing. So, I try to make sure that the practice sets are race worthy.
Great point regarding carpet and other interior components for the interior yet many "non stock" parts are allowed in other parts of the car. I'd love to know what the rationale is behind this rule.
OK first, We all know we hate the carpets move on to keep this thread productive lol
I think you have some great ideas larry, the onlt problem stems from cars that are already built. A very large part of the newer "stock" class cars have expensive upgrades in them. I also dont know any tire company that makes enough sizes besides hoosier to keep a spec tire working. As far as motors are concerned there is Stock and not stock. there really isnt much gray area, but it seems more and more fall into the second catagory
Larry-
Good ideas. However, I have an idea that I think might be even simpler. Why not create two versions of Weight/Hp (GT and Stock) and add a few more classes of weight/hp but tighten them up.... The tighter the classes, the less someone will feel the need to spend a lot of money to get to the top of the next class....
Also, with two classes, those that don't want to spend a lot of money can stick to the stock (maybe even have modified and prepared point additions) classes and those that want to go crazy can run in GT.
At the end of the day, as long as you have several totally different chassis with different engines running against each other, you end up having to make some wacky rules to get apples and oranges to be the same. Under this scenario, it will NEVER be really fair.
As far as the carpet goes, it's a fire hazard!!!!
Basic Site Sponsor
Basic Site Sponsor
Get off the internet & enjoy Paris.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Larry-
I believe that classing in stock should be such that each car's classification weight is based on performance or estimated power/weight relative to its class.
For example the 944 Turbo, 944S2 and 968 all have class weights based on their curb weights. However the 3 cars all have the same tubs and really should have race weights adjusted to even up power/weight ratios and some additional weight factors for things like allow brakes, gearbox and such. This can make all the cars more equal in the same class.
Now if you ditch the need for carpets in the car and shift some cars publish min weights up/down 100 lbs to equal the classes I think you will have better racing and can take the edge off some natural overdogs in the stock classes. So if the numbers show you car is a little down on power for the class take out 100lbs and see how it does. That can really help ensure that more of the cars listed for a class can compete.
Now I believe each car should really have 3 classing options in "stock". Super stock which would be mininal suspension mods, stock with current suspension mods and no carpet, prepared which is current preppared with no carpet. Super Stock should be heavier than stock and stock heavier than prepared.
Anyway I think that would help even up the stock classing they way you create more classing option with out more classes is just do the move up /move down thing with in the current number of classes.
This brings up an intersting point. Right now stock classes are based partially on stock power levels and stock curb weights. Sure their is now a modifier for driver weight, but the weight a car runs at in stock is not related to its competition and how fast or slow it is in class, but to the weight Porsche published for a stock street car.
