Spun the new R888 on the rim
#31
Spun my R888's this weekend. Spun the fronts more than 1/2 way around and the rears about 1/2 way around. ARRRRGH....my race shop is going to use the bead sealer and see if that helps.
#32
One more for Aquanet. It works well as the lub for putting on the tires on then sets up and secures the bead to the rim. I marked the tires and after the Aquanet, no rotation. I was seeing up the 90 degrees before this.
#33
Larry did I tell you that I will never buy full tread R888's again, scare the crap out of you new out of the box. Yes I was not braking hard becuase the car was scary loose in to the apex. They have settled down but not as good as my Corsas were.
