Looking for suggestions on thermal hose sleeve
After relocating my coolant expansion tank, one of the rubber coolant hoses lies closer to the engine than I would like. It will probably be ok and several mechanics have assured me that it will be. However, one of them mentioned an orange sleeve product that would help. He said that it was orange, couldn't remember the name, and thought that BSR products carried it. I've had no luck tracking it down .... any ideas what it is or where I could find it? (BSR wasn't any help.)
The orange fire sleeve works well. There is also a silver, reflective coated sleeve which is available. In addition, there is a DEI Cool Tube which seems good. All are available from www.HRPworld.com I've used the orange sleeve and silver sleeve effectively. Here are all their heat protection products:
http://www.hrpworld.com/HeatProtecti...ction=category
You can also paint the hose with a Xylene based heat reflective paint. It's very good. I'v used it on insides of carbon fibre body panels which are exposed to high heat. The ALMS corvette team has used it on their spark plug wires, as did some IMSA GTP teams on the insides of the engine covers. It's called "LO/MIT-1 Radiant Barrier Coating". It adheres to rubber, carbon fibre, fiberglass, metal, anything. It is very reflective for both heat and light. It's diffuse reflectivity is similar to polished aluminum. It is better for something with "nooks and crannies" when compared with protective sleeves. It's available from Solar Energy Corporation in Princeton, NJ.
Good luck!
Good luck!
They probably do but became impatient with my lack of appropriate technical terms to describe what I wanted. "Sleeve to protect rubber hose from high heat." They've always good so I figure it was just a fluke on the phone, no big deal but then hoped someone here might have the answer too.
Good luck!
Good luck!
The LO/MIT-1 Radiant Barrier Coating (Xylene based paint) is good for dealing with radiant heat issues. It basically does the same thing as the protective foil (gold or silver) and the silver reflective sleeves. I seem to recall it is about $50 per gallon. However, 1 gallon will last for 179 years of race car prep at least. The orange, fiberglass based sleeve also has an insulating property to it. So, for air conductive heat problems you may need that property. It does not help prevent radiant heat issues as well as the reflective coatings (foil, sleeve, paint). Usually for hoses near an engine it is radiant heat soak which is the issue though since there is a lot of air flow around the motor.
Anyway, it's probable that one of the sleeves you've looked at will be enough. Good luck!!
