camera mount options without roll bar
I had a lot of luck with mounting a cheap nannycam to my helmet with heavy duty Velcro... Then I used my camcorder as a VCR to record it.
http://www.youtube.com/watch?v=yMuir...layer_embedded
Paul, does the 997 cab have little square receptors to hold the windscreen in place (in the 996, they are just behind the front seats, near the seat belt anchors). If so, then try the following:
1/4" steel pipe square plugs (2)
1/4" to 1/2" steel pipe reducing connectors (2)
1/2" steel pipe nipple (3ft)
1/2" steel pipe nipple (sized to fill remaining gap)
1/2" steel pipe connectors (qty as required to connect the pieces into a single piece as follows:
plug+reducer+pipe+connector+pipe+..... +reducer+plug
The plugs at each end will fit perfectly in the windscreen receptors and hold the assembled pipe in place. You'll have to fiddle around with different lengths of pipe in order to screw it down short enough to get the plugs inserted, and still be able to later unscrew it enough to expand the length back to where it exerts solid pressure against each side.
"You guys and your cabs... Get a coupe."
Oh wait, someone already said that.
The 997 uses the same windscreen as the 996.
I thought about building something like that only using aluminum and having a support that extends back to the rear seats and uses the rear seatbelts in addition to the windscreed mounts to secure it.
I posed the question to the forum before I went off and started building something.
I see another pcar in my future that will ultimately become a dedicated track car.
Paul
Paul
Paul
BTW, the pipe I used came from the hard-top carrier, which just happens to have pre-cut holes in all the right places to make this work. None of the coupe bigots out there will understand this when I say "that's the best use of the hardtop option I have ever seen!"
Here's a crappy phone pic with both approaches installed. (Set up for 2 cameras). Total cost was less than 50 bucks. (much cheaper than a new car).
